Hey guys, I have an 80 SG with broken tab on the choke lever. A replacement lever has been elusive. Does anyone have an idea for other levers that may work with the SG? Thanks.
Choke lever options
There's lots of broken levers out there....
There's two types, a zinc-plated version used on the early bikes and some later standards, and the chrome-plated ones used on later bikes including your SG. They will interchange, but are shaped slightly different.
Why not fix what you have? Faced with the same problem, I repaired mine.
If you look closely at the carbs, I cut/shaped a piece of 1/8" aluminum to fit on the back of the existing lever with a new tab sticking up and fastened it on with two 8/32 buttonhead allen screws. Works great, and is nearly invisible.
Do make sure you clean/lube all the friction points in your choke linkage so it moves easily...Fast, Cheap, Reliable... Pick any two
Yes. There's two different designs/finishes used on the XS11 carbs...Fast, Cheap, Reliable... Pick any two
I got rid of my lever altogether and attached a chrome cabinet knob, it threads on to the existing enrichener rod. IIRC, I had to use a die to make the proper threads on the rod...
Originally posted by bikerphil View PostI got rid of my lever altogether and attached a chrome cabinet knob, it threads on to the existing enrichener rod. IIRC, I had to use a die to make the proper threads on the rod...
I got one from a local junkyard. It wasn't the same shape, as it was from an earlier model, but it fit just fine.1980 XS850SG - Sold
