Choke lever options
  • CUBuffs
    • 252
    • Castle Rock, Co
    Choke lever options
    Hey guys, I have an 80 SG with broken tab on the choke lever. A replacement lever has been elusive. Does anyone have an idea for other levers that may work with the SG? Thanks.
    80 XS11 SG
    79 XS750 SF
    74 KZ400
    78 KZ650
    78 KZ750
    There's lots of broken levers out there....
    There's two types, a zinc-plated version used on the early bikes and some later standards, and the chrome-plated ones used on later bikes including your SG. They will interchange, but are shaped slightly different.
    Why not fix what you have? Faced with the same problem, I repaired mine.
    If you look closely at the carbs, I cut/shaped a piece of 1/8" aluminum to fit on the back of the existing lever with a new tab sticking up and fastened it on with two 8/32 buttonhead allen screws. Works great, and is nearly invisible.
    Do make sure you clean/lube all the friction points in your choke linkage so it moves easily...
    • CUBuffs
      • 252
      • Castle Rock, Co
      By "Early bikes" you mean earlier XS11's?
      80 XS11 SG
      79 XS750 SF
      74 KZ400
      78 KZ650
      78 KZ750
        Yes. There's two different designs/finishes used on the XS11 carbs...
          I got rid of my lever altogether and attached a chrome cabinet knob, it threads on to the existing enrichener rod. IIRC, I had to use a die to make the proper threads on the rod...
            Doing it that way, you lose the spring tension on the lever's hinge that keeps the choke lever pressed in though. Not that I would expect the choke shaft to go flopping around by itself, especially with the detent balls in there, but it might be a potential issue.
            I got one from a local junkyard. It wasn't the same shape, as it was from an earlier model, but it fit just fine.
              Never had any problems with it popping out of it's set position, YMMV.
