Those I have never seen; that doesn't mean somebody doesn't make 'em, but I have no idea of where to look. You might want to get another harness and rob them off of it...
so what would be a solution to my problem? insulated crimped connectors instead of a plug? or maybe encase everything in an epoxy? I'm sure everyone has the same problem...that plastic was not made to last 30 years....
Dependent on whether it's a "RESTORATION", or a resurrection as to if you'll want to find an OEM plug from an otherwise broken/torn/burnt up harness, or do something like what you said, using or even making our own plug out of separate connectors? Geezer is a good guy, visit his site and then drop him a line and ask him if any of his 4 or 6 slot plugs have the same spacing as the OEM TCI plug, you might be able to make one using combo of plugs!?
79SF "The Teacher" . . .basket case! History shows again and again,
At this point it's a resurrection ....if, and when I get it running I will think about restoring it...I like to keep things original whenever I can....
