Help needed with rear brake
  • Volant1006
    • Apr 2010
    • 20
    • Leesport, PA
    Thanks in advance for any advice that is given.
    Needed to put new pads of the back because of wear. When I went to push the caliper back in with a C-clamp, the thing would't budge past a certain point. By lossening the bleeder screw I was able to get the caliber pushed all the way in to give me enough room to put the new pads on. Once I put everything together and tried hitting the brake...nothing. The pedal pushes all the way down, but the wheel doesn't stop.
    Do I need to rebuild the caliper? If so, does anyone know were I can get the parts??
    The Mean Machine --> www.pennstelite.com/XS1100.htm
    1980 XS1100SG
    1981 XS650SH (sold)
    1980 XS650SG (sold)
    2002 Polaris Edge X 800
    2004 Dodge RAM 1500 Hemi
    "I may be going to hell in a bucket, baby, but at least I'm enjoying the ride " -GD
  • jwhughes3
    • 2798
    • Home of the Alamo
    Spooge hole blocked
    Sounds like a classic "spooge hole" blockage. You need to take rear MC apart and clean the tiny spooge hole (allows fluid return from caliper). You may not need parts. If you do, check here: http://stores.ebay.com/GEORGEFIXS-MOTORCYCLE-PARTS
    John
    '81 XS1100H - "Enterprise"
    • mjpxs11sh
      • Jan 2011
      • 299
      • N/E, Illinois
      u've come across a comon issue with the rear brakes. follow this link. hope it helps you.
      Max
      81 XS1100SH Black Beast Mutt
      Kerker 4/1
      stock carbs and air box.
      78 headlite, handle bars,
      1 set of ea-160/85mph guages,
      crash bars, cruise control
      Other 2 Wheelers
      78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
      94 CBR1000F jet kit,Two Bros pipe, K&N Filter
        If you don't know the history of the brakes, it could very well be 'stuff' in both the master cylinder and the caliper. I'd highly recommend removing both and fully disassembling/cleaning them. You could also have a rusty caliper piston (common problem) that will need to be replaced. Replacements can be found here: http://hvccycle.com/brake-caliper-pistons.html . These guys also sell seal kits, etc.
        If you find 'stuff' in the rear, the fronts are probably just as bad; you really should go through all the brakes. 99% of the brake problems on these bikes is due to contamination/corrosion of the system from age. New seals are rarely needed unless your bike has high miles (say over 50K) or really bad corrosion.
        • Volant1006
          • Apr 2010
          • 20
          • Leesport, PA
          Sounds good guys. I'll start by taking apart the rear caliper & master cylinder to make sure there's no gunk or worn out parts. Thx!
          1980 XS1100SG
          1981 XS650SH (sold)
          1980 XS650SG (sold)
          • Volant1006
            • Apr 2010
            • 20
            • Leesport, PA
            My master cylinder looked to be in good working order I ended up ordering a new caliper for the back. Put the new caliper on, new pads, bled the brakes, & presto, works like a charm now. Thanks for the feedback.
            1980 XS1100SG
            1981 XS650SH (sold)
            1980 XS650SG (sold)
            • mikubuilder
              • Jul 2011
              • 548
              • Westland, Mich.
              sooo....what's less expensive? new caliper or new piston and seal kit?
              Nick
              1982 Virago 750 (it's alive!)
              • jayel
                • Apr 2012
                • 152
                • Birmingham, Iowa
                taking it apart, giving it a good cleaning, putting it back together and if it works properly all you have spent is time
                where are we going, and why are we in this hand basket?
                Iowa the Beautiful Land 1980 XS1100SG
                • jayel
                  • Apr 2012
                  • 152
                  • Birmingham, Iowa
                  dang double post
                  • Crazy Damian
                    • May 2012
                    • 48
                    • Carlisle, Ohio
                    I had similar problem
                    I had almost the same problem all around on the brakes on my XS when I first got it, cleaned both master cylinders, then 1 at a time I took each caliper apart cleaned, re-lubed and assembled, didn't have to buy any seals at all.
                    You will notice, especially on older motorcycles, that sometimes the brake piston(s) will be pitted, this is usually not a problem, but if the piston comes out but doesn't go back in, a very common problem is the seal that is inside the caliper that the piston pushes through, usually the seal is not bad, but corrosion has built up in the grove behind the seal, which causes it to push the seal out a bit putting too much pressure on the piston, carefully remove the seal and I usually start with a dental pick and then finish with a small piece of 3m scotch brite, clean with brake cleaner , re-lube and assemble.
                    Damian
                    If it's worth doing, It's worth overdoing!
                    Ride it like you stole it, or get out of my way.
                    Don't worry if others don't like it, if you like it just smile and ride!
                    1979 XS1100SF w/ Flanders "Superbike" Handlebars,
                    Upcoming mods include but not limited to, ZRX Carbs, 4-1 exhaust, and a gun fighter single seat, lots of paint, chrome and powder coating.
