air box rebuild step by step with photos?
  • MR.D
    • May 2012
    • 40
    • jasper, GA.
    hey guys well i found a set of carbs but now i am having to make one air box out of two is there a link or anyone have a air box step by step how t rebuild?
    78 E
    Follow this link to a diagram on BikeBandit.
    You can also find one on the Official Yamaha Parts Fiche site:
    Official Yamaha Motor Website | Motorcycles, ATVs, Boats & More. Explore Yamaha Motor's official website for the latest in motorcycles, scooters, ATVs, side-by-sides, boats, outboards, waverunners, golf carts, and power products. Innovation, performance, and reliability from a brand you trust.
      The one thing you need to keep track of is which inlet/velocity stack is which. They only fit 'right' one way; the inner two are the same, but the outer two are side-specific.
      • MR.D
        • May 2012
        • 40
        • jasper, GA.
        well i think i got it all right. going to get lunch then try to put the carbs and box on. might have to take the carbs back of to clean.
        78 E
          Test-fit the airbox to the carbs before trying it on the bike...
          • MR.D
            • May 2012
            • 40
            • jasper, GA.
            its a stock carb set
            78 E
              The reason I suggest a test fit is to make sure the inlets are all correct...
              • mikubuilder
                • Jul 2011
                • 548
                • Westland, Mich.
                I made a rookie mistake of taking those two philips screws from top bracket outand the other two on the sides as well and I tell you...if you're patient it's not too bad to put it all back in LOL
                Nick
                1982 Virago 750 (it's alive!)
                • MR.D
                  • May 2012
                  • 40
                  • jasper, GA.
                  thanks. i did get the box on but now have other problems.
                  78 E
                    One other thing that should be mentioned when swapping carbs/airboxes; while the boxes all look the same and will interchange, there is one mechanical difference. The 78-79 carbs have separate float bowl vents that go to nipples on the airbox. The nipples are on all the airboxes, but aren't drilled on the '80-81 versions. So depending on which carbs/airbox you have, you may need to drill or plug those nipples...
                    • MR.D
                      • May 2012
                      • 40
                      • jasper, GA.
                      tell me more maybe thats part of my problem. could ya give a ring
                      78 E
                        You've got the late carbs IIRC, so you don't need the vents. If the vents are open on the airbox, you should plug them...
