Is this possible?
  • mstic2000
    • Aug 2008
    • 574
    • Saginaw, Mi
    Is this possible?
    Just wondering if it is possible to bore an XS1100 to 1300? Never heard of that one before...
    XS1300?
    My 1978 http://img.photobucket.com/albums/v518/mstic2000/xs.jpg
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    XS1300?
    From discussions on here, the biggest "off the shelf" big bore kit is 1196 cc. I think anything beyond that you need to get special pistons made... The guy probably doesn't know what hes talkin about.
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      May be possible, but you would need new cylinder sleeves and custom pistons made.
      • Wildkat
        XS Special Gurette
        • Apr 2004
        • 3416
        • Location, Location
        There have been two members that have done this.
        Dan Hodges and one other (just can't recall who it was at the moment)
        I'll try to find some of the posts if you're interested but they were years ago...
        Here's a link to one of Dan's posts regarding the 1300...
        Dan Hodges' 1300 project
        Oh! there WAS a member called Viper who had an engine bored out to 1500.
        The bike was called Thor.
        I did a search but there wasn't a lot of info for that one...
        81 SH Something Special
        79 SF MEAUQABEAUXS
        81SH Nor'eas tah (Old Red)
        80 LG Black Magic
        78 E Standard Practice
        James 3:17
        “Alis Volat Propriis”
        Yamaha XS 1100 Classic
        For those on FB
        • mstic2000
          • Aug 2008
          • 574
          • Saginaw, Mi
          Thanks Wildkat
            Seems to me the cylinder walls would be so thin that it would overheat easily.
            • Rooster
              • Oct 2009
              • 84
              I know a machinist that would do whatever was necessary to do that for me, he said, "leave to me leave your amex platinum number and I'll get everything to you in about 6 months," then he asked how many donor engines do I have in case he destroys one or two in the process.(mind you he was laughing his head off while wondering about a project this large on a japanese bike from '79) His forte is racing engines but this was beyond his comprehension and my cash flow.(No Drag Bike For Rooster)
              Even a blind monkey gets the odd banana.
              1979 XS 1100 special (been down the PO trail and it was messy)
                The 1196 is as large as you can go with the OEM sleeves; to go bigger, now you're talking about custom sleeves and boring the cylinders/cases for the larger spigots. So this means a complete engine teardown....
                As to the overheating issue, yes, this is real. How thin the sleeve gets really doesn't matter (other than having issues with dimensional stability), but you've only got a finite amount of cooling fin area, so that's why Dan recommended a oil cooler (really, it should be mandatory). Where you really need the fin area is on the head; I was looking at big-bore cylinders for my Sporty where you can get everything from a OEM-style aluminum cylinder/machined sleeve, Nicasil all-aluminum cylinders, or a all-cast-iron cylinder. The last choice sheds heat the poorest, but has superior dimensional stability and better longevity. They've found that Harley's shed about 60% of the heat out the head and HD heads have generous fin area, so these work well on bikes that don't block airflow over the motor. The XS head doesn't have that 'extra' fin area...
                • Mathh
                  • Nov 2006
                  • 699
                  • Beek, Netherlands
                  Dan Hodges calculated a max of 1311 cc. That's more than what i calculated: 1295cc with a 77.5mm bore. That's because I measured the smallest wall thickness as 2.5mm between cylinders 1 and 2 and 2mm at the stud holes.
                  but for fasr riding an oil cooler will not suffice, you'll need oil cooled pistons (oil sprayed to the bottom of the pistons as some manufacturers do).
                  MV Agusta Brutale 910R '06.
                  Yamaha MT-09 Tracer '15 grey.
