ELECTRIC? I just want to ride.
  • XSessiveForce79
    • Sep 2010
    • 34
    so here I go,this may take a while.
    I have a 79 ( 2H7-022441 ) standard ? Weisco big bore (74mm) kit. DynaTek coils , I believe DC-1 ? ( the ones TC recommended ) plus the Dyna wires , 8mm , with stock (?) plug ends. The ballast resistor has been bypassed.
    With pods,jetted up,and stock header pipes w/after market mufflers.no
    baffles. ran real good.
    Posted about it not starting all the time. Had to drop it in gear, bump it, then hit the starter again.sometimes it would start. sometimes not.
    Then it seemed I had to do that (above) and pull the clutch lever in ( in neutral ) and it would start instantly.???? STRANGE ?
    So now, current condition. no spark.
    cleaned and the replaced the kill switch.
    battery 12.7 volts. drops to 10.9 while cranking
    checked.cleaned.and reconnected coil connections.
    11.75 volts to grey coil wire on one coil
    same to orange wire on other coil
    with ign. on
    same voltage to white wires with red stripe
    ign.on
    cranking, DC volts, pos. lead on orange / neg to ground on frame 1.5 volts
    same for grey on other coil.
    cranking, DC volts, pos lead on either white with red stripe / neg to ground on frame.8.9 volts
    switched TCI out with known good TCI. no difference.
    Tested coil pickup ohms at TCI connector.
    Yellow with green TO yellow with red wires. 700 ohms
    White with green TO white with red wires. no reading
    Tested same wires back to connector behind fuse panel.
    ( which has been a blade type for a few years now )
    wires tested fine for continuity and ohms
    Tested the pickup ohms,right at the wires,1/2 inch off the pickups.
    700 ohms
    Tested that lead back to the connection by the fuse panel.
    the ONLY reading I get there is between the black wire and the grey wire.
    700 ohms
    though I don't know why suddely the black wire appears , the orange or baby blue wires don't have any reading at all . no readings in any combos.
    I pulled on the coil pickup wires pretty hard. no spagetti. seems solid enough
    do you think it is a bad wire,from the coil pickups to the first connector? I hope someone else can gleen some ideal here because I really want to ride now that the rain might finally be getting back to normal ( what really is ? )
    anyhow,Thanks ahead of time.sure is a strange bike.but it kinda just takes over doesn't it.
    You should real "ol" or open line or 0 for the wire from the plug behind the fuse panel to the TCI. Is the is any reading other than that then there is a problem with those wires. Try running jumper wires from that plug to the TCI. Don't even worry about that 5th wire in the middle of the plug, that is just the neutral light.
      Hey there,
      How old is the battery? From 12.7 to 10.9 at the battery is a considerable drop, and it is probably dropping more at the TCI...below the 10.5 volts the TCI needs to work properly. If you have one of those jumper booster batteries connect a jumper wire to the terminal on the Ignition circuit on the fuse block.....so you are feeding a good 12 volts to the ignition circuit, and then try starting the bike. It will probably start just fine! This will tell you that you probably need to clean many of the harness connectors including the ones at the TCI, grounds as well to try to reduce the voltage drop at the TCI.
      But also get your battery load tested....it may be getting old and can hold a surface charge, but doesn't have the depth to provide the needed voltage under the cranking load!
