calling all gurus, carb question
  • cloerts
    • Mar 2007
    • 153
    • Tahlequah, OK
    So I pulled my carbs off because my bike wouldn't start. I figured things were probably just gunked up and messy. I took them apart and cleaned all the likely spots, then reassembled. It made no difference. My next suspicion was that some obscure little passages were clogged. So I dipped the whole carb bank in a chem bath, up to just below the diaphragms, and let it soak for a couple of days. I drained them, put them back on the bike and it started right up with no hesitation. But... the bike instantly revs up to 8000 rpm. I didn't adjust anything, the throttle is in the correct position, and the floats are working. I filled and drained the bowls four times thinking that maybe the chem bath was responsible, but it makes no difference. What the heck is going on?
    Casey
    1980 xs1100g "Frankenstein" (Now with a mind of his own!)
    "What do you mean I can't park this thing here?"
    "Shiny side up? I don't have a shiny side."
    • 9980
    Your throttle cable isn't seated properly or your linkage at the carbs is bound on something. Very possibly a boot clamp.
    • cloerts
      • Mar 2007
      • 153
      • Tahlequah, OK
      Boot clamp. brilliant! one boot clamp was out of position, but I left it there thinking it wouldn't matter too much. You sir are awesome! Thank you.
      Casey
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        Maybe his idle setscrew is in too far.
        If it wasn't running well before, maybe the PO moved the idle up to compensate for the dirty carbs.
        Bench sync those things first. (ie. make sure all 4 butterflies are just barely open) before putting them back on the bike.
        Edit: I see that you figured it out. Great!
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
          My concern is that you have soaked the carbs and the butterfly shaft seals in the chemdip....it eats up the seals, and you can get severe vacuum leaks that can also cause the vac. synch inbalance and unwanted revving!
          I hope it was just the stuck cable, but just thinking out loud!
