i think i screwed up...
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    So I was reinstalling my camshafts, and I thought I had the dots lined up with the t mark, but this is how I ended up...the t mark is off but both dots are even...
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    Wolf
    Moto Militia MC
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      Question, is your cct installed? In other words is all the slack out of the timing chain?
      If so, then I've got something for you to look at.
      On the other side of the cam sprockets the 2 bolt holes, one of them has a little 'crown' (best word I can think of to describe it) above the hole.
      With the dots lined up both sprockets line up with these 'crowns' up too.
      I know it sounds weird, but it happened to me, I had one of my sprockets 180degs out and the dots were just a hair off.
      Someone here posted pics showing it and sure enough that was it!
      Edit. I just saw the pic of the timing plate and it looks like you may be a tooth or two off.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
      • airborneXS
        • Feb 2012
        • 338
        • Houston, TX.
        Those 2 teeth are up with the dots lined up...yes the cct is in...
        Wolf
        Moto Militia MC
          You're off by at least one tooth on both cams...
          • airborneXS
            • Feb 2012
            • 338
            • Houston, TX.
            So what do I need yo do?
            Wolf
            Moto Militia MC
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              Pull the cams again and reset your engine to the T mark, then install your cams again. Make sure you have the slack out of the chain when putting them back in and the chain is on the sprocket on the crank. If yours is anything like mine, my crank was dead nuts on the T mark but the dots were just slightly off. I fiddled around and move the cams back and forth 1 tooth to see if it would line up better. I was finially convinced it was where it needed to be... visit the acct threads, there is a lot of discussion and tips that can help you. As mentioned above, there is a mark on the sprocket at one of the bolt holes that serves as a marker to orient the sprocket on the cams properly. The mark is suposed to line up with the dot in the cam...
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
                Yep, you need to re-align the cam chain. Several options here, but first is pull the tensioner to give the chain some slack. Then either remove the bolts from the cam sprockets, but essentually, you need to be able to move the cam chain on the cam sprockets while you turn the crank. You do nto want the cams to turn though.
                  Once you take the cams back off this would be a PERFECT time to verify your T mark is actually correct, they often can get bent over the years.
                    You don't need to pull the cams; you do need to disassemble pretty much all the rest though.
                    Pull the CCT, the cam guide between the cams, and the bolts holding the sprockets on. Now rotate the crankshaft clockwise to the 'T' mark, making sure the cams don't turn. Now you can disengage the cam sprockets and move them the one or two teeth you need on the chain to line them up. This can be a bit finicky... Once you get the sprocket holes lined up on the cams, that should be it. Make sure the cam chain is still on the crank sprocket, reinstall the CCT, and rotate the motor once to verify the timing. I only install one cam sprocket bolt until I'm sure the timing is right...
                    • airborneXS
                      • Feb 2012
                      • 338
                      • Houston, TX.
                      Thanks guys I think I got it...now if I can just get this old hardened gasket off...lol
                      Wolf
                      Moto Militia MC
                      • mack
                        • 2411
                        • Ontario, Canada
                        Do not
                        allow the cams to rotate. Get the sprockets off the cams as Steve says, before you rotate the engine to TDC, then start over from scratch. Be careful using a wrench to rotate the cams to the proper position once the pistons are at TDC. It's easy to break the gallery casings with the wrench.
                        mack
                        79 XS 1100 SF Special
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        https://youtu.be/wB5Jfbp6SUc
                        https://youtu.be/RaI3WYHSuWA
                        Frankford, Ont, Canada
                        613-398-6186
                          You should have loaded that thing up and come to San Antonio last weekend.
                          • airborneXS
                            • Feb 2012
                            • 338
                            • Houston, TX.
                            Well I got a little overzealous tightening my valve cover and cracked one of the bolt tabs...what are the torque specs for it? Its a hairline crack...can I just jb weld it?
                            Wolf
                            Moto Militia MC
                              Torque is 7.2 ft-lbs, I'd use some RTV around the area after repairing it with JBW.
