Hearing a slap after auto cct change and valve clearance job
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    FWIW, when I did the ratchet CCT switch, I never heard the plunger pop out and my chain slapped around and skipped a couple teeth. As I was removing it, I heard the "zip-pop" of the plunger extending. I reset the cam-chain timing, reinstalled the plunger (hearing the "zip-pop" this time), and all was well. The bike ran, but poorly, a couple of teeth off, but much better after retiming.
    I have no idea why it didn't extend the first time.
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      I think in the original post, someone recommended taking a screwdriver and inserting it into the CCT to push out the plunger manually before installing the spring. Dont use much force, just enough to get it to extend and make contact with the chain. This will ensure the plunger has deployed and you wont have a problem like you described. The final tension will come from the spring when torqued in... JAT
      Originally posted by Cuda 69
      I have the 700 Raptor ACCT in my SG and no noise difference at all,if anything,it runs smoother.Hope you find the problem.
      I agree, the noise level didnt increase but it did change. I think the noise from the chain was removed and allows you to hear the cam/tappet noise more clearer...
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • Pancala
        • Jan 2012
        • 67
        • Shawnee, OK
        Here's a vid of the noise. Tried to get it where the mic could pick it up the most
        1980 XS1100SG(First bike, sold)
        Other bikes
        1976 Kawasaki KZ400 (project)
        1983 Yamaha XV920 Midnight Special
        1984 Yamaha XT250 Enduro (project)
        • James England
          • 3039
          • North of England
          Personally, I think that sounds quite loud. The video was taken inside a garage though, wasn't it? That does make noises sound different but, even so, my own autoCCT did not sound as loud as that.
          I'm wondering if your chain is badly stretched. I would remove the CCT and see how far the plunger has deployed. If a lot, then I'd say your chain is loose. If not deployed much, then your chain is OK.
          I'm not saying it is this, but a header pipe/cylinder head gasket leak can sound like your video. I realise that the noise was not there before the CCT change though, so it's not likely to be that. But maybe worth a check.
          • Pancala
            • Jan 2012
            • 67
            • Shawnee, OK
            Thanks for the reply!
            I have new header gaskets on there so I don't think it's that. I'll check to see how far the plunger is extended tonight after work.
            For the first 50 miles she ran perfect after the acct change, it's just when missed 2nd gear and she revved up high and backfired on the way down that the noise started.. A compression test would rule out a head gasket, right?
            And yes, the video was taken in the shop. But it is very noticeable outside also
            Other bikes
            • Pancala
              • Jan 2012
              • 67
              • Shawnee, OK
              it was the headers loose.. I guess I should make time other than at midnight to work on it so I'm actually thinking logically.. I should have checked because last week I found the spark plugs loose also.
              Thanks to everyone for all of the help! Gonna take her for a long ride to make up for her being stuck in the shop since Sunday.. Haha
              Other bikes
              • James England
                • 3039
                • North of England
                Great you found it. I remember that noise from my old Triumphs (which leaked regularly from the header pipe to cylinder head joint)... it can sound like a metallic slapping. In your case, I'm pleased it was that, as it's an easy fix!
