Throttle lock assembly?
    How does this thing go together? I need something so I can take my hand off every now and then!
    It came with the bike when I got it a few years ago. It was not installed when I got it, just sitting in the fairing pocket.
    I believe the part sticking up in the right side of the photo slips into where the throttle cable housing bolts up. I'm sure you figured out the whole thing slides onto the throttle before the grip.
      Yeah that much I assumed. Although it seemed that no matter what orientation I put the lock part on the ring it didn't seem to function right.
          Hmmm, I will have to try again tomorrow.
            Jets pic pretty much explains it. Either a phillips screw or allen adjust the 'squeeze' pressure and that lower slotted tab(looks like a rear gun site) wedges between the metal curve where throttle cable goes into housing to hold it stationary from rotating. Simple, takes bout 2min. to install and adjust, and work well, so good find.
            • petejw
              • 2269
              • sydney australia
              hey nate,
              dont kno if it helps but heres
              an old pic of mine
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • GARTHXS
                • Nov 2007
                • 1631
                • Seattle
                You want to have it loose enough so you can still twist the throttle
                91 kwaka kz1000p
                Stock
                ( Insert clever quote here )
                • WSL91
                  • Feb 2012
                  • 427
                  • Quad Cities, IL
                  Looks like its missing the piece that anchors it to the throttle block. Mine as a formed sheetmetal piece that is attached with the linger screw under the throttle housing where the throttle cable exits. That piece is formed and the plastic part is held in place by that. Something has to hold the plastic part to the bars otherwise it will just rotate with the throttle
                  1970? Honda Z50... gone
                  1974 Honda CB200... gone
                  2008 Honda VTX 1800F
                  http://www.johnsoldiron.com
                    • 5073
                    The "fork" at the bottom will couple with the throttle cable gooseneck. This is what prevents the thing from rotating around. I have these on my xs11's. I believe they are Nepps brand. If that is what you have, when adjusted properly, there will be three positions:
                    One will allow the throttle to spring back normally,
                    another will be a "soft" position that takes some of the spring force off of your gloves,
                    and finally, a harder lock that completely holds the throttle in place whith your hand off of the grip.
