Stripped oil filter bolt
  • mstic2000
    • Aug 2008
    • 574
    • Saginaw, Mi
    Just picked up a 78 XS 1100 and found that the oil filter bolt wasn't in great shape when I tried to get it off. I ended up stripping it round and gouged it pretty good with some vice grips. It wouldn't budge! Harbor Freight has a 9 piece metric bolt extractor set on sale right now for $19.99. I picked one up and the 12mm socket took it right off with no problem. I put the head on a grinder and put some flat spots back on it and put it back in the bike with a 12mm 12 point socket. It tightened right up. When I take it out the next time I will just use the bolt extractor socket. I'll eventually end up replacing it but it won't stop me from riding this holiday weekend!
    My 1978 http://img.photobucket.com/albums/v518/mstic2000/xs.jpg
    I hope you can get it off next time! These things are frequently overtightened.
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      Which is a shame, since the torque applied has NO effect on the ability to seal. In fact, I would bet that with the proper o-rings installed, it could be installed finger tight, and not leak, and not back out. CZ
        Well, it might be challenging to get a new big oring to seal at the cup contact using your fingers. However, you get the thing too tight with all of the components having oil or grease (I get the big one to stay in place this way) on them will definately cause the oil to migrate away with time and pressure! Torque on does not equat torque off...
        • mstic2000
          • Aug 2008
          • 574
          • Saginaw, Mi
          It came back off with the bolt extractor socket. I didn't fill it with oil last night and decided to check some boxes full of spare parts today before I did put the oil back in. Lo and behold I had a spare oil filter bypass bolt and the head is in great shape.
            Some filters come with a thinner O-ring and then I tighten the crap out of the bolt. Of course I use the correct/good quality tools and have never had a problem <knock> stripping the bolt head in 20 yrs, YMMV.
              Harbor Freight has torque wrenches on sale.
              http://www.harborfreight.com/catalog...=torque+wrench
              I went the other day and bought a 1/4 drive for $9.99 and a 3/8 drive for $13.49. Using a tq wrench can save a lot of grief later on. This is especially true for the untrained and/or inexperienced home mechanic. Here's an inexpensive solution!
              • mstic2000
                • Aug 2008
                • 574
                • Saginaw, Mi
                I can still get the original yamaha oil filters hear at the parts dealer where I am at for about $10. I tighten the oil filter bolt snug and check it after a few days and never had a problem with leaking. I picked up a 12 point metric socket set at Harbor Freight when I got the bolt extractor set. Much more better on these old bikes. I might be making a trip back there for a torque wrench.
                  Return those 12 point sockets and get 6 point. 12 point Is just asking to round off a bolt.
                    Ditto! And good quuality socket steel is better yet.
                    • mstic2000
                      • Aug 2008
                      • 574
                      • Saginaw, Mi
                      I have a set of craftsman 6 point sockets. In my years of wrenching experience 12 points grab where a 6 point can't. The bolt extractor set is a pretty handy item too.
                        I have had the opposite experience. It is usually the softer bolt head that rounds off the points when things go wrong. A six-point wrench involves more of the metal on the bolt head to prevent rounding. I think it is a matter of shearing resistance.
                          I find this true with flank drive sockets. Mine are Bonney brand. Snap-on makes them that way. Otherwise, I find six point the safer bet.
