Grease Those Splines Boys!!!
    That zerk fitting is useless.....
    49K on the bike (the XJ I bought), plenty of grease in there (gobs inside the shaft tube) but it wasn't getting to where it needed to be. Looks like a good idea to pull the FD and manually lube these, ya think?
    The splines inside the coupler are just as bad; too bad, the FD seems fine otherwise.. Time to go digging in the spares.
  • 11Rider
    • Aug 2010
    • 331
    Holy smokes. Could you give a little more detail on where these gears are? Far as I know the final drive is lubed by the gear oil so I must be missing something.
    '79 XS11 Special, fork gaiters, Uni pods, 45 pilots, 140 mains, ditched the octy, solo seat, T kat fork brace
    Purrs like a kitten, runs like a scalded cat
      That's the driveshaft splines that go into the coupler on the final drive. They're supposed to get greased by squirting grease into that zerk fitting on the swingarm right in front of the FD. Doesn't work too well....
      • WSL91
        • Feb 2012
        • 427
        • Quad Cities, IL
        The face width of the gears is fairly small considering you could be putting 90hp on them. I was surprised when I did the final swap.
        1970? Honda Z50... gone
        1974? Yamaha 100 Enduro... gone
        1974 Honda CB200... gone
        1981 Yamaha Virago 750... gone
        1993 Honda Shadow 1100... gone
        2008 Honda VTX 1800F
        1982 Yamaha XJ1100J w/850 final, Raptor ACCT
        1979 Yamaha XS1100SF "Chewey" Raptor ACCT
        http://www.johnsoldiron.com
          Those are the FD end of the drive shaft. They slide into the splined coupler of the FD. Which lives in the ballooned out end of the swingarm where the FD connects. That is where the grease (zerk) fitting is Steve referred to.
          That thing still had to be beat pretty hard to get that tore up. But the corosion shows how little grease got in there for sure.
            That is nasty looking!!
              Ebay is full of those driveshafts starting at $9 so they seem pretty plentiful, not the end of the world if it wears out.
              • James England
                • 3039
                • North of England
                I took my zerk fitting off and blanked it off. It's completely useless. The FD needs greasing manually, 100% sure...
                • BobBaldy
                  • Apr 2012
                  • 43
                  • Evansville IN
                  Funny, that's the next thing on my to do list after I get back from a family reunion. I already drained the final and middle. Any tips I need to know beyond what's in the Clymer manual before I grease this puppy manually?
                  80 G, Spaghetti pipes, K&N in stock airbox, Galfer S/S lines.
                  It has been my experience that folks who have no vices have very few virtues. -Abraham Lincoln
                  http://80xselevenrebuild.blogspot.com/
                  • ViperRon
                    • Feb 2011
                    • 1062
                    • Woodstock, VA
                    I know you are replacing that shaft but for it to be worn that bad then the splines in the final drive have to have wear also. Put a good shaft against it and even greased it will wear quickly. Thanks for putting the evidence in peoples face, pictures are worth a thousand words and maybe seeing is believing.
                    Rodan
                    1980 G Silverbird
                    1198 Overbore kit
                    Grizzly 660 ACCT
                    Barnett Clutch Springs
                    R1 Clutch Fiber Plates
                    122.5 Main Jets
                    ACCT Mod
                    Mac 4-2 Flare Tips
                    Antivibe Bar ends
                    Rear trunk add-on
                      I would bet that the FD spline steel is harder than the driveshaft steel and did not wear much at all.
                        You would lose that bet.....
                          That is insane!
                          • trdriver71
                            • 360
                            • Edmonton Alberta
                            the wear looks alot like the speedo drive on my bike that looked like it hasn't had any grease in it for a while.
                            '79 XS11SF
                              Steve, that is pretty bad wear, I never would have thought. OK, 11 FD's are a dime a dozen tho. That bike must have had one sloppy(er) drive train.
