Final Drive Conversion Question
  • Roadman48
    • Apr 2012
    • 39
    • Central Ohio
    I am in the process of changing over the final drive of my 79 XS1100 for one from an XS850 that I purchased used. It came with the pinion assembly out of the housing. As I try to re-assemble it, it is a very tight fit. What is the best way to accomplish this? Is it okay to tap in with a hammer or is there a better way? Thanks.
    Larry
    1979 XS1100SF
    1981 XJ650 Maxim
    1981 XS650 (Frame off rebuild/mild custom)
    1981 SR500 (Pristine Stock Original)
    1979 XT500 (Configured as a TT500)
    2008 HD Sportster (With Texas Ranger sidecar)
    1967 Honda 305 Scrambler (Frame off restoration)
    1966 Honda S90 (Frame off restoration/My first bike)
    Some lube and some wiggling. I wouldn't hit it with a hammer.
      Why was it disassembled? That makes me suspicious of whether or not the gears match.
      You'll need to check the lash for sure.
        Apply some heat.... I had mine apart and heated the main housing in a oven at 200 degrees for about 1/2 hour, the pinion slipped right in...
        • Roadman48
          • Apr 2012
          • 39
          • Central Ohio
          Thanks. I appreciate all the responses.
          Larry
          1979 XS1100SF
          1981 XJ650 Maxim
            • 8930
            It should go in lightly tapping it "around the clock", BTDT. When the pinion is to be removed a slide hammer is needed, it is a very precise fit.
