Possible stupid question
  • Jeff Pattee
    • Sep 2010
    • 21
    • Eugene, Oregon
    Other than the color coding and possibly the length of the spark plug wires, is there any reason why a left coil wouldn't work on the the right side (for 2 & 3)??? My right coil went deep sea fishing on me, but I do have a spare left one........I don't know of any reason why it wouldn't work, but, tis better to be safe than lose an ignition box.
    "Pop.pa Pipes"
    Tends to overthink even the smallest little glitches
    1978 XS1100
    '79 Special Tank
    210 air pilots, 137.5 Mains
    4 into 2 Jardines
    1st over, standard bore
    1978 Intake cam
    Later style exhaust cam
    • 8930
    They are the same and can be interchanged.
    • Jeff Pattee
      • Sep 2010
      • 21
      • Eugene, Oregon
      coils
      Thanks Phil......I'll do it tomorrow
      "Pop.pa Pipes"
      1978 XS1100
      '79 Special Tank
      4 into 2 Jardines
      1978 Intake cam
      • GLoweVA
        • Jun 2011
        • 1957
        • Virginia Beach, VA.
        I agree, as long as the wires are long enough to reach #1 & #4.
        80G (Green paint(PO idea))
        The Green Monster
        Got him in '04.
        bald tire & borrowing parts
        Scarlet
        Got her in '11
        Ready for the twisties!
        81H (previously CPMaynard's)
        Hugo
        Cold weather ride
          And as long as the spare coil is the 2H7 series, not the ones for the 81 and later models. Your 78 uses the 1.5 ohm coils, with the 1.5 ohm ballast resistor for a total of 3 ohms that the TCI sees. Using the later series coils would both provide too much resistance....that won't hurt the TCI, but you won't get the proper spark strength since the later coils are built for full 12 volts all the time, the 78-80 are designed for ~9 volts...what they get after the 1.5 ohm ballast resistor.
