How to repair missing tips
  • tcoop
    • Nov 2009
    • 793
    • South Weber, UT
    When I got this XJ1100 the right petcock was missing the tips or nipples to attach the fuel lines to. Is ther any way to repair this or do I need to buy another set? (Or at least the right side.)
    Ty
    78 XS1100E - Now in Minnesota
    80 XS1100LG - The Punisher
    82 XJ1100 - Daughter's Bike
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    Are they missing compleatly? If not i would dismantle and solder it back on
    1980 gs1000g "stock"
    • tcoop
      • Nov 2009
      • 793
      • South Weber, UT
      Yea they are gone. I never had them.
      Ty
        • 5069
        Is there room to use drilled out blessed nipples?
          • 5069
          Correction! I must have been having a Freudian
          moment about boobs. I meant "brake bleeder nipples." Maybe you can drill and thread holes in the petcock piece for that?
            • 9980
            I would just look for another on fleabay if I was you. http://www.ebay.com/sch/i.html?_nkw=...fuel&_osacat=0
            or maybe another member has the parts. Those brass nipples are just pressed in. I'm running short here.
            Make sure you get the correct one.
              Sometimes mine come out when removing a particularly stuck-on fuel line for carb removal. I just tap them back up in with the wooden handle of a hammer. I suppose you could disassemble it and sweat them in with some solder, but it's really no big deal to tap them back in and they don't leak.
              I just looked at the parts listing and it doesn't give a part number for just those brass nipples.
              Something you COULD do, if you no longer have the fuel octy on there, is carefully remove the front nipple from your other one and place it into the rear spot of the other petcock. You can either plug up the hole to the front one.. or just never switch the petcock to prime, as this would run fuel out the front hole.
                • 9980
                Only thing is, he's missing the brass tips altogether.
                  Tod is saying to take the nipple from the prime post of the other petcock and put It In the place of the on/reserve nipple on the other petcock and the plug the prime ports on both petcocks.
                    • 9980
                    OK, I see now.....
                    • tcoop
                      • Nov 2009
                      • 793
                      • South Weber, UT
                      May have found a fix
                      Here's what I did. My wife wanted to go to Home Depot for some shelving brackets(pantry shelf fell off the wall this morning ). So while we were there I checked out the plumbing department to see if they had brass fittings. I figured it wouldn't hurt.
                      Found diferent sizes of these,
                      Bought a few different sizes so that I didn't have to go back to HD today. Found that the one tha fit the closest was the 1/4 barb
                      Put it in the vise and cut the middle stop out.
                      Had to file the barb that would fit into the petcock some then sodered it(not sure if i did a good job on that)
                      Now to test it to see if it leaks. If this does not work I will be looking on EBay for the right side.
                      Ty
                      • WSL91
                        • Feb 2012
                        • 427
                        • Quad Cities, IL
                        I doubt that you can solder them to the die cast metal used for the casting. The originals were likely pressed in. If you get something that fits right a tight a wipe of JB weld before pressing back in would work. We use that in a similar application on Ford tractors pressing the steel oil fill tube back into the cast iron block.
                        1970? Honda Z50... gone
                        1974? Yamaha 100 Enduro... gone
                        1974 Honda CB200... gone
                        1981 Yamaha Virago 750... gone
                        1993 Honda Shadow 1100... gone
                        2008 Honda VTX 1800F
                        1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                        1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                        http://www.johnsoldiron.com
