Get in there, damned oil!
  • Fix
    • May 2009
    • 384
    • Lake Orion, MI
    I did a filter and oil change today. Drained the oil, took off the filter, cleaned the oil cleaner housing...the usual. After I put it all back together, I put in 3 quarts of oil and it's showing full on the center stand. The manual and past experience says I should be able to put 7/10ths of a quart more in there with the filter change.
    Does this indicate I did something wrong? I don't see any reason the oil wouldn't be going into the filter housing.
    I put the spring, then washer, then filter in, just like always. New small and large o-rings and Wix filter.
    I'm gonna leave it sit tonight, maybe it's just being slow, but I wanted to see if anyone knew if this is gonna be a problem.
    Thanks!
    Mike C
    Lake Orion, Michigan
    '78 XS1100E
    Here I am! Where are you?
    The oil filter won't fill up until you run the motor...
    • jjz28
      • Apr 2012
      • 1023
      • Beckley, W. Va.
      Yeah, i started mine and the level went down and then put more in.
      77 XS750 2D completely stock
      • James England
        • 3039
        • North of England
        100% correct. You need to run the engine for a minute. Your oil level will drop as the housing fills. Then re-check and add the extra oil
        • tv5150
          • 352
          • Central Tejas
          Let It Sit a While
          After the initial start-up, be sure and let it sit a good 10-15 minutes to allow the "cool oil" to drain
          and settle back down in the crankcase before adding any more to level it off.
          Much easier to add a little than to have to remove too much
          Current Rides:
          02 GL1800 Wing
          79 XS1100SF Sold 10-15-12
          81 XS1100H Venturer Sold 10-27-12
          • Fix
            • May 2009
            • 384
            • Lake Orion, MI
            Thanks gents!
            Mike C
            '78 XS1100E
            • mikubuilder
              • Jul 2011
              • 548
              • Westland, Mich.
              +1...need to crank motor
              Nick
              1982 Virago 750 (it's alive!)
