Originally posted by jjz28
View Post
Clutch slipping in 3rd
'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
In my opinion since it is near impossible to "feel" when you make contact and sync e the clutch is close I would suggest just loosening the lock nut and then back the center adjustment screw out 1/8 turn and then lock down the nut. Drive it and see if the slip is gone. Re adjust is needed and repeat till you are good and then.put the outer cover on again.Nathan
Originally posted by natemoen View PostIn my opinion since it is near impossible to "feel" when you make contact and sync e the clutch is close I would suggest just loosening the lock nut and then back the center adjustment screw out 1/8 turn and then lock down the nut. Drive it and see if the slip is gone. Re adjust is needed and repeat till you are good and then.put the outer cover on again.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
Originally posted by WMarshy View PostI recommend going in with the set screw, it will move the engagement point closer to the bar IIRC.Greg
Thanks for all you advice guys, i will find out in the morning. I dont have to work tomorrow. I am wondering if it has a little pressure on it all the time and slipping just a little bit all the time. I cant hear it and it has awesome power but i dont have a tach either.Jeff
77 XS750 2D completely stock
When you are adjusting it there comes a point where you do not dissengage the clutch plates and it will intermittantly chatter and grip when handle is pulled all the way in. If you get to that point and the clutch still slips in third under full power and the felts and steels in basket are in good shape like mine now are buy new springs. Get Barnett springs cause many here complain about the EBC.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
Well, i adjusted it today and went to take it out and it seemed to be letting out in the same exact spot. went ahead and got on the highway and romped it in 3rd And it slipped. Its funny cause it dont slip until the higher rpms when the bike is already moving pretty fast. It seems like it would do it when the bike is going slower and it takes more torque to get it going. I only did it once though. But I downshifted from 4th to 3rd and shot to it and it took off like a rocket and was pulling good then rev up like i pulled in the clutch so i let off. I dont have a tach but couldnt feel it slipping before. It started pouring the rain on me. I need to adjust again though cause it was in the same spot as before it seems.Jeff
It slips in the higher gears because the engine and clutch are working harder, just like it's harder to pedal a 10 speed bicycle in the higher gears.
Change the clutch springs.Greg
Yep, time for springs man. For about $40-45 you can get friction plates from Parts'n More.com; the combination of new friction plates and those Barnett springs are a winning solution. Especially if you are going to go through the trouble of taking apart your clutch pack to rough up your steel's with some sand paper, its worth replacing the frictions.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
I havent bought the springs yet, been too busy. Is there a way to shim the factory springs with a washer? I havent been in the clutch so i dont know what its like in there. I was thinking maybe i could rough up the steels and shim the springs and take it out today and see what happens.Jeff
Originally posted by jjz28 View PostI havent bought the springs yet, been too busy. Is there a way to shim the factory springs with a washer? I havent been in the clutch so i dont know what its like in there. I was thinking maybe i could rough up the steels and shim the springs and take it out today and see what happens.
all 6, the last one i did i used 4 washers, doesnt make the lever so stiff,
but u need to put the washers opposite each other.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
Thanks pete, i adjusted it again and also the po had zip tied the clutch cable the handlebars, It does better now but i think i will still get the springs and install later. The bike run so good today and yesterday, i think i have it all sorted out now, course i need a synch, it still has never been synched.Jeff
