Fork Question
    Originally posted by Toolmaker Tim
    ...so can I use the fork tubes from my spare set of standard forks to replace them while using the guts and sliders from my special tubes?
    Besides what Phil mentioned (mechanical differences in the design), the standard fork tubes are about 4" shorter than the special tubes...
    • Toolmaker Tim
      • 671
      • South Bend, Indiana
      Yes, Rasputin, I can screw it up.
      I guess I will be ordering new seals. When I went to install them they buckled and deformed. I am thinking I put them in upside down. So much for me handling a simple repair. I'll order new seals and try again.
      1979XS1100SF
      K&N's and drilled airbox
      Jardine 4in1
      Dunlop Elite 3's
      JBM slide diaphragms
      142.5 main jets
      45 pilot jets
      T.C.'s fusebox & SOFA
      750/850 FD mod.
      XV 920 Needle Mod.
      Venture Cam Chain Tensioner
        • 8930
        Are you saying that the seal buckled when installing into the lower leg or when installing the stanchion tube?
        • Toolmaker Tim
          • 671
          #34
          Seating them into the lower leg. They were super tight, so they twisted and ripped. I also wonder if there is a diffence between standard and Special seals.
          1979XS1100SF
          Jardine 4in1
          Dunlop Elite 3's
          142.5 main jets
          45 pilot jets
          750/850 FD mod.
          XV 920 Needle Mod.
            • 8930
            Yes there is, I hope you didn't try to drive in the Standard seals, they are 1MM larger O.D. You need 37X48X10.5 for the Special.
            • Toolmaker Tim
              • 671
              #36
              Yes, I am that dumb
              Thank you for solving that problem, I'll get the correct seals and try again.
              1979XS1100SF
              Jardine 4in1
              Dunlop Elite 3's
              142.5 main jets
              45 pilot jets
              750/850 FD mod.
              XV 920 Needle Mod.
              • Toolmaker Tim
                • 671
                #37
                Ok, I just ordered a set of special seals from George Fix. Try again
                1979XS1100SF
                Jardine 4in1
                Dunlop Elite 3's
                142.5 main jets
                45 pilot jets
                750/850 FD mod.
                XV 920 Needle Mod.
                  • 8930
                  Lol, you're welcome, it oughta be way easier installing them this time.
                  • Toolmaker Tim
                    • 671
                    #39
                    Easier?
                    Putting them in maybe, I going to get one of those seal pullers and hope the ones I tried to put in come out easy. Now where was that garage stud I was using to pound my head against?
                    1979XS1100SF
                    Jardine 4in1
                    Dunlop Elite 3's
                    142.5 main jets
                    45 pilot jets
                    750/850 FD mod.
                    XV 920 Needle Mod.
                      • 2101
                      Cheap Seal Puller...
                      ...can be aquired here:
                      http://www.harborfreight.com/catalog...?q=seal+puller
                      Also this might help:
                      http://www.ebay.com/sch/i.html?_trks...river&_sacat=0
                      GL
                      • Toolmaker Tim
                        • 671
                        #41
                        Seal Pullers
                        Thanks Schming, but they came out easily. A little pry with a screw driver and out they came. New seals will be here tomorrow judging by the USPS tracker. so we will give it another whirl. Always an adventure.
                        1979XS1100SF
                        Jardine 4in1
                        Dunlop Elite 3's
                        142.5 main jets
                        45 pilot jets
                        750/850 FD mod.
                        XV 920 Needle Mod.
                        • Toolmaker Tim
                          • 671
                          #42
                          I Hate Forks
                          Went to install the springs after reassembling the forks all prepared to have to wrestle the fork caps back on....... and nothing. Checked the Clymer manual and they tell me the springs should be 24.10" minumium free lenght, mine are 23.8" free length. Ok, it's only .3 short, and it is an air assisted fork. Do I or should I add a spacer?
                          1979XS1100SF
                          Jardine 4in1
                          Dunlop Elite 3's
                          142.5 main jets
                          45 pilot jets
                          750/850 FD mod.
                          XV 920 Needle Mod.
                            • 8930
                            Yes, adding spacers will help some, but is just a band-aid for sacked springs. I would put at least a 1/4" PVC spacer and an extra washer so it doesn't ride directly on the spring. You can make a tool like this from 2X2 to install the air caps...
