I have a replaement seat cover for an 81H and it is to be "stapled" onto the pan. I have replaced 78E seat covers using the teeth-like tabs on the pan to secure it in place. How is the later model cover staped onto the pan?
Stapled seat covers onto pan?
If you have a stock steel pan those little finger ripping points will do the job. Some aftermarket pans, like Corbin, are fiberglass or plastic and you need to staple them.Greg
Hi Skids,
they are all held on the same way, the cover is spiked onto those jagged teeth and then the teeth are bent over.
But what to do if those teeth break off when you are removing the old cover?
Or when they are bent down again to hold the new cover on?
One time I bought a generic cover that came with S-section spring clips.
The inner half of the clip held the cover onto the seat pan and the outer half held on a trim strip that hid the clips.Fred Hill, S'toon
"The Flying Pumpkin"Comment
I had(Have?) a seat that the cover is held on with rivets. You could only tell from looking at the underside. (the rivets didn't penetrate the outside of the cover.
This is(was?) and after market plastic/fiberglass pan.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
The older Corbins like we tend to use are Corbin's metal pan and pop-rivets are used underside. My original 81Venturer seat(still new) in the closet uses the attached pointy metal tabs to hold cover tightly in place.Last edited by motoman; 05-15-2012, 03:11 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
