New to me 1982 XJ1100
  • Wouldstalk
    • Mar 2012
    • 37
    • Stockton, CA.
    Right. Because 2 and 3 are the fuel intakes for the octy and 1 and 4 are the outputs. You connect the Prime port on the petcocks to a tee in the hoses in the middle of the output lines which allows the Prime port to bypass the octy. If you apply a vacuum to the octy, you can blow into 2 or 3 (block off the other one) and the air will flow out of 1 and 4 at the same time.
    Lol, I cant believe how much more sense that makes then what i thought i knew. Not that the octy causes any major issues or confusion but thanks just the same!
    • Arthur6
      • May 2012
      • 7
      • Reno, NV.
      OK...
      Filled front tire(was flat).
      Cleaned the bike, looks good.
      Charged battery.
      Hooked up the fuel lines(THANKS to you guys on here).
      Shot some Either into the air box.
      Bike started.
      I poured some gas into the tank, bike ran OK.
      Changed oil - drained about 4 quarts, filled with the required 3.
      Rode down the block, all gears check out good, clutch works fine.
      Considering selling it... may be more than I'm ready for.
      82 XJ1100 Maxim
