vacuum lines
    replied
    Originally posted by Eastcoaster
    Where should the small one in pix 3 in front of the crankcase breather it go? Mine just dump down under the bike Is that right?
    It connects to a bracket above the airbox and is open to the atmosphere.
    Leave a comment:
  • Eastcoaster
    replied
    Leave a comment:
    replied
    If you don't have an airbox you need to go to the auto parts stor and find an oil breather filter to hook up there somehow. That'll keep dirt and water from entering the crankcase.
    Look in the shiney chrome accessories department.
    Leave a comment:
  • Eastcoaster
    replied
    Pix 3 the larger one in the pix is crankcase breather that goes to the air box. The smaller one pointed rear on mine has a short piece of hose open ended if you still have an air box on the bike It should have a breather tube that connects from that point to the air box I have been lookning all day for a hose that matches it at the auto parts store The hose is a very thin wall If your air box is gone I think you can just run a short piece off the connection
    Leave a comment:
    replied
    That's not a fuel pump it's a fuel valve, commonly known as the octy because of it's resemblance to an octopus. The vacuum line for it goes to the intake boot on the #2 cylinder. The vacuum line coming out of the left engine cover is for the vacuum advance unit and it goes to the nipple on the front of the #2 carburetor.
    That last photo is of the crank case vent and it hooks to the top front center of the airbox.
    Leave a comment:
  • 1980cm400t
    started a topic vacuum lines
    vacuum lines
    Does anyone know which carb insulator the vacuum advance line goes on? I think it is the 2nd cylinder on the LHS but I'm not sure (see picture 1 and 2). Also what is the purpose of the small hose connection on the crankcase (picture 3)? I think it is the vacuum line to power the fuel pump but I'm not 100% certain.
