Now That It's Running Good It needs to Stop Good
  • va_blue_stang
    • Aug 2011
    • 97
    • Bluford Il 62814
    After all the help the bike is running great but stopping is an issue. The brakes are fairly good now but the front left brake has been unhooked from the rear master cylinder. It has no proportioning valve on the master cylinder now.The master is off an '80 model, it has two line hook ups in the back of it but someone has bolted one off. What can I do to get the left front brake back going again this bike is heavy enough that I would like to feel comfortable with the braking.
    Thanks everyone for the help, Mitch
    82 XJ1100
    Very Little that is factory left.
    Large mix of XJ/XS parts
    You'll need the brake line setup off of an XS. Both front calipers working off the handlbar MC and the rear being independant. The XJ has a system that the rear and the left front are linked and work off the foot pedal. A lot of people didn't like that and blocked off the left front. It works OK that way but I'm like you. I want all I can get.
      You really should replace the front master with one from a XS special too. The existing one is designed to only operate one caliper, the bore is a bit small for two IMHO...
      • WSL91
        • Feb 2012
        • 427
        • Quad Cities, IL
        I did that about a month ago.
        1970? Honda Z50... gone
        1974? Yamaha 100 Enduro... gone
        1974 Honda CB200... gone
        1981 Yamaha Virago 750... gone
        1993 Honda Shadow 1100... gone
        2008 Honda VTX 1800F
        1982 Yamaha XJ1100J w/850 final, Raptor ACCT
        1979 Yamaha XS1100SF "Chewey" Raptor ACCT
        http://www.johnsoldiron.com
          And you still have no LF brake? Is the caliper frozen?
          • va_blue_stang
            • Aug 2011
            • 97
            • Bluford Il 62814
            I went for good long right yesterday on some great curvy back roads, and running with only the right front brake hooked up and working and the rear only was a hairy experience with two up riding. If I would of had to stop quick for any reason it would have been all over but the slow walking and sad singing.
            Now better braking is going to be a must. I'm going to check out the front left caliper and see what it looks like in a day or two when I have time to take it off.
            82 XJ1100
            • va_blue_stang
              • Aug 2011
              • 97
              • Bluford Il 62814
              I went to check the fluid in the front master cylinder when I realized that some jackhole before I got the bike had rounded out both screws completely. What's the safest and best way to remove them without destroying the master cylinder?
              82 XJ1100
              • GLoweVA
                • Jun 2011
                • 1957
                • Virginia Beach, VA.
                Probably using a dremel cut off wheel to notch those screws so you can use a flathead screwdriver.
                I'd suggest getting the cutoff wheel to a fairly small diameter so as you cut into the screw head, you don't cut into the cap.
                Maybe pick up some replacement screws so you don't have to put those notched out ones back in.
                You could also try some PB Blaster to make sure those screws will come out easier.
                80G (Green paint(PO idea))
                The Green Monster
                Got him in '04.
                bald tire & borrowing parts
                Scarlet
                Got her in '11
                Ready for the twisties!
                81H (previously CPMaynard's)
                Hugo
                Cold weather ride
                • va_blue_stang
                  • Aug 2011
                  • 97
                  • Bluford Il 62814
                  The dremel idea was the same thing I thought of this morning. I figured it was worth a shot when I get time to work on it.
                  82 XJ1100
