Is this from an XS1100 or an XJ1100?
  • blubill
    • Apr 2012
    • 5
    • Champaign, IL
    82 XJ 1100
    XJ. It has the proportioning valve for the linked front left/rear brakes.
    • blubill
      • Apr 2012
      • 5
      • Champaign, IL
      I'm sorry about the short message, basically I am in the process of unlinking my brakes on my XJ11. I have completed the front with the use of a double banjo bolt and copper washers. For the rear I was just going to pick up a rear cylinder from an XS11. How can you tell if one is from an XJ or an XS?
      82 XJ 1100
      • blubill
        • Apr 2012
        • 5
        • Champaign, IL
        Thank you!
        82 XJ 1100
        • mikubuilder
          • Jul 2011
          • 548
          • Westland, Mich.
          I agree, as the XJ has a left front brake fed from rear master...
          Nick
          1982 Virago 750 (it's alive!)
            Only the LH/XJ has the cast-in reservoir, the XS master reservoirs all are plastic...
              • 3182
              One has to remember that the 81MNS also has the linked brakes which confuses the question a bit.
                • 3182
                Good info Steve.
                  Pretty much the same part except the XJ master cylinders (front and back) have level indicators built in, which the LH lacks. So the wiring coming out of the body identifies that as an XJ part.
                    • 3182
                    See I am learning more every day on this site.
                      The XJ one is a little larger bore as well. The bore diameter is stamped on the side of the reservioir. As far as I know, the rebuild kits for the LH are unobtainium. The XJ kits are available from Chacal (link in my signature).
