Blown Transmission?
  • JoshKeast
    • Mar 2012
    • 53
    • Treynor, Iowa
    Blown Transmission?
    I was going down the interstate and I heard the bike "stutter" and the back tire sorta locked up for a second. I pulled over and gave it a once over and then took off again thinking I just hit something. Rode another 15 miles to my destination.
    Now, I can put the bike in neutral, start it, but it will not push more than 3-5 feet before something catches and the back tire starts dragging. I'm pretty confident it's not the rear caliper/brakes. I tried to start in first and the back tire locked up and the bike ended up on its side. I decided to just park it there and pick it up later. Second gear was out of it and I've been riding it, just skipping past second so I'm afraid something broke loose and wedged in the tranny or something....
    Ideas?
    1981 XS1100 Special
    "A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed." 2nd Amendment
    Did it make any noises as it happened?
    • JoshKeast
      • Mar 2012
      • 53
      • Treynor, Iowa
      Maybe a small "clunk". Nothing major that made me concerned at the time. but now that the back tire is locking up, I think back to the "stutter" on the interstate 15 mins before and I'm thinking they have to be related.
      1981 XS1100 Special
        • 9980
        I doubt if it's the transmission, it's possible though. More likely it's the middle or final drive.
        You have no choice but to fix it now. Get the wrenches out.
        Drain the middle and final drives and see if there is any metal shavings..........or chunks.
        • mlew
          • Jun 2005
          • 226
          • Apex , NC
          Drive shaft U-joint could be locked up.
          Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
          Current rides:
          80 XS1100SG
          82 JX1100
          83 Venture Royale
          86 V-Max
          • Rasputin
            • 3189
            • Lacombe, Alberta, Canada
            Like BA80 says it sounds like it is in the middle or rear drive. Check fluids and see if the rear moves with the clutch pulled in. If it is a middle or final drive you will not be able to turn it while the trans is in neutral or the clutch is disengaged, or at the least you will hear it. Any, even short lock up of the rear tire is very dangerous so proceed with caution.
            2-79 XS1100 SF
            2-78 XS1100 E Best bike Ever
              Could be any part of the drive train, but the most likely is the middle drive in my opinion. Only because of its wierd drain location it gets overlooked frequently.
              If it were me, I'd start at the FD and see where the shafts loosen up. Meaning pull the FD off, then see if the driveshaft or u-joint turn easily now. Still locked up, pull the U-joint. Same test, now pull the middle drive. At that point the middle drive will input and output shafts will let you figure if its the MD or not.
              • ddragon63
                • Jan 2012
                • 1101
                • Ridgefield, WA
                Ya sounds like a mid or final to me too... its very uncommon for a constant mess tranny to grenade and lock up while just moving forward. Now if your were clutch dropping or speed shifting I can see it, but not just mashing down the hwy. my .02
                Don
                old:
                1989 kawi ex500
                1996 yzf-r6
                1999 yzf-r1
                2001 kawi zx-6r
                2000 Ducati 748
                2002 YZF-R1
                2005 V-Star 1100 Classic
                  • 7765
                  I have TWO engines that have bad transmissions. Both have at least one gear on the MAIN SHAFT missing a tooth, or three. The PO said the bike just locked up on him, and the second time he parked it.
                  It IS possible it's the transmission, but as others have stated, start at the back. My choice would be the 4 bolts at the middle drive U-joint, as that will split the problem, and it's then just one of two from there.
                    • 7941
                    The reason I didn't do the "Dremel Fix" on my trasmission was that my XS650 broke a dog off. If someting like that tried to pass through the trasmission, I expect it would be felt at the rear wheel.
                    I agree with the others. Start at the final drive and work forward. Be prepared to have to drop the pan if you don't find another failed gearbox.
                    You may come out of this with an education and a functioning five speed transmission.
                    • JoshKeast
                      • Mar 2012
                      • 53
                      • Treynor, Iowa
                      Well it sounds like majority rules, Ive given the best description I can and most if not all of you (who are way smarter than me) have stated it's most likely in the drive shaft. I will be going to get the bike sometime this weekend so,.... any idea on the approximate cost to fix a driveshaft problem????
                      I know it's gonna be cheaper to fix the problem, so getting a different bike is out of the question, I just am feeling discouraged that I've spent so much time and money fixing this thing and just when I think I'm out of the woods, I fall right back into needing to fix another problem that prevents me from riding.
                      1981 XS1100 Special
                      • JoshKeast
                        • Mar 2012
                        • 53
                        • Treynor, Iowa
                        Also, could be an unrelated or even non-important problem but when the bike is idleing, i hear what I can only describe as a lifter tic only louder. It's very rythmyic and sounds like it's coming from the top end of the engine. My dad said he didn't think motorcyles had lifters and I haven't the slightest clue. It was running pretty good so at the time I didn't think too much of it. Maybe this motorcycle is too much of a project for a novice to take on...
                        1981 XS1100 Special
                        • James England
                          • 3039
                          • North of England
                          If it's the middle gearbox, it will be easy enough to replace and not particularly expensive. It is a pretty steep learning curve for a novice but not impossible, by any means. Especially given the resource you have here with the forum.
                          I would remove the middle gearbox first and see what's what...
                          • jjz28
                            • Apr 2012
                            • 1023
                            • Beckley, W. Va.
                            mine had a ticking sound the other day and most of my header bolts were loose. Tightened them up and the sound was gone and it sounded like a lifter.
                            77 XS750 2D completely stock
                              • 7941
                              The valve train is noisey when properly adjusted.
                              There are no lifters. You have overhead cams that work the valves through a bucket & shim arrangement.
