octy
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    octy
    rebuilding my octy...
    1) how does the plastic piece and the rubber gasket thing go in?
    2) in the rebuild kit, it seems the gasket for the petcock where the petcock connects to the tank is a little small...
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
    • 8050
    IIRC, the rubber membrane is two sheets. The white plastic piece goes in between them. There are dimples in the metal, holes in the membrane, and nubs on the plastic piece to line everything up. They did their best to make it Murphy proof.
    The key is to get the surface where that little o'ring sits very clean. I used a small piece of fine Scotch Brite, and followed up with a pencil eraser. (I learned that trick from someone else on this forum.) Get the parts in proper order and very clean, you should have success.
    If you have the K&L kit the round o'ring will fit on the petcock. Hold it in place with Vaseline.
    • airborneXS
      • Feb 2012
      • 338
      • Houston, TX.
      is that how it goes? i didnt take a pic before taking it apart ( i know, i know, stupid me.... ) back plate, rubber gasket, plastic plate, then front plate ( the piece for the gas lines ) ?
      also theres a vent hole or whatever in the plastic plate, which way does that face? down?
      Wolf
      Moto Militia MC
        • 8050
        Wolf,
        It appears to me that you have assembled that valve incorrectly. I found a very good step-by-step on another forum, complete with photographs. The instructions are for a vacuum petcock, but if you look carefully, you can glean every bit of information you need to restore your shutoff valve.
        http://xjbikes.com/Forums/viewtopic/p=219609.html
        • airborneXS
          • Feb 2012
          • 338
          • Houston, TX.
          i dont see how its possible to get the plastic piece in between the 2 rubber pieces on the gasket, as the gasket is one piece, and i cant separate it. when i took the octy apart the plastic piece was not in between the 2 pieces of rubber
          Wolf
          Moto Militia MC
            IIRC, the plastic piece does not go between the 2 pieces of rubber. Both layers of rubber lay on the same side of the plastic piece. Although I may be mistaken...
            • airborneXS
              • Feb 2012
              • 338
              • Houston, TX.
              nevermind now i really feel retarded...as i was looking at it again and playing with it, it hit me...the answer was so unbelievably easy....my bad...
              Wolf
              Moto Militia MC
              • airborneXS
                • Feb 2012
                • 338
                • Houston, TX.
                so does the plastic piece go in between the two pieces of rubber or not? ive gotten 2 different answers...crap!
                Wolf
                Moto Militia MC
                  Sorry, now that I re-look at the pictures, I remember how it works. The metal side has one piece of rubber, and the other side should kinda roll up and push through the hole to the other side. And the vent notch should be on the opposite side from the metal circle.
                    • 8050
                      Just like the picture Marty shows, the plastic piece is sandwhiched between the two rubber "gaskets" of the diaphram piece. The rubber serves a dual purpose, to flex as the valve moves, and to seal.
