How much fuel should flow from the petcock? What kind of stream should it have? I got rid of my octi and have been running on reserve because my "on" doesnt flow fuel. Should i run the prime side instead of reserve? Im not sure i am getting enough fuel flow.
fuel flow
You need to remove and disassemble those petcocks if your getting no flow when in the on position. They are probably full of gunk.
The petcocks are pretty simple and straight forward.
You will have NO reserve if you run them in prime or reserve position. Not a good idea.Greg
The list changes. -
yeah, tear the taps down because something ain't right.
BTW, you shoulda capped off the PRIME spigots when you ditched the octopus. To run on PRIME you will have to put a fuel hose back on the PRIME spigot and Tee it into the ON + RES fuel hose both sides.
As has been posted, running off PRIME, same as running off RES, will run you completely out of fuel if you don't carefully watch for the red "low fuel" light to come on. If the bulb ain't blown.Fred Hill, S'toon
"The Flying Pumpkin"Comment
jat,
have u made sure ur running a full/ near full tank of fuel
to check out the petcocks?pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Thanks guys, i have tried with full tank of fuel, the thing is, I just dont know if i am getting enough fuel to feed the carbs good enough in the high rpms. I have been having a kinda low in stumble and then it rockets off and then a higher end stumble at wot when i get to the higher rpms (tach dont work but I know its not over redline). I am not synched though, just eyeball benchsynced. The thing is if im riding slow around town and then open it up in second or third it will seem to run out strong in the high rpms the first time but then it seems like I dont have enough gas to do it again, like maybe the fuel builds up running slow and fills the bowls and it will pull good and then after one good pull it misses at high rpms the next time. It runs good and isnt a very big stumble/miss at all and it isnt like i am getting no fuel like I forgot to turn on my petcocks, it not that bad at all just a little flutter up high. Maybe its cause I aint sycned.Jeff
77 XS750 2D completely stock
79 SF XS1100 "Picky" stock with harley mufflersComment
are u running the stock main and pilot jets?
also are u running the stock float setings,
are both the petcocks flowing at the same rate
or is there definately one flowing faster than the other,
if u have the fuel lines 't'd together, then 1 petcock
working correctly would feed enuff fuel for the carbs.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
no i dont have them t'd together, i have the running staight down to the carb. I had to cut the gas line really short so it would not kink. I do the on flows better than the other. Everything is stock on the bike except for some harley like exhaust. I just realized that 2 carbs are fed by each side, I was thinking all 4 were hooked together with t's. So if one petcock is flowing slower, those 2 carbs would get less gas. I am going to try to T i today and see what happens. Thanks a lot.Jeff
You could also try a throttle chop test after your first high RPM run. It sounds like perhaps your running rich in on the mains. Starting to foul out the plugs at hgih RPM, then running on the pilot circuit it clears them up. If you do nto give the pilot circuit time to clen them up, the mains start fouling them out.
Just another thought on it.Life is what happens while your planning everything else!
78 XS750Comment
I just checked the fuel flow and the flow the same amount. I put new plugs in it yesterday and the look great. I will try the chop today. I am going to try and find someone with the gauges to synch it.Last edited by jjz28; 05-03-2012, 06:37 AM.Jeff
But to answer your question, last time I measured it was something like 8 oz. per minute each as I recall. I did not write it down. Still, if plumbed with a crossover then one cock will run the motor at WOT.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
I think mine would be way more than that. I had about 1 1/2 inch in the bottom on a jar in 5 seconds. Counting 1 one thousand 2 one thousand, so I am sure in a minute it would be more than 8 oz. That is just running it out of the petcock into the jar.Jeff
Float Hight?
I would check to make sure your floats are adjusted right before i synced them. I had simmilar issues with my bike. I found that the floats were smashed down causing my bike to flood the engine. I got that fixed and had it synced and she runs great. Thats just my 2 cents and something to try. Im not sure on the specs but i think i set my float hight to an inch. Hope this helps.80 XS1100G Black Betty (Daily Driver)
79 XS1100SF (Buddys Project)
82 XJ750 Maxim (Fathers Bike)
81 CB750F SS (Buddys Project)
06 GSX600F Sold! (Was Mine)
81 XS1100 Failed Bobber Project (Mine)
81 XS1100 Parts (Mine)
Grip it, Rip it, and Stick it!!!Comment
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
78-79 carb floats are to be set between 24.7mm and 26.7mm. 25.4mm is 1", and right in the middle of spec. Measurement is from the gasket surface to top of float, with gasket removed.1979 Yamaha XS1100SF (gone)
Airbox w/K&N element
Jardine 4 into 1
145 mains, 45 pilots
1996 Ducati 900SS CR
1977 Kawasaki KZ900-A5
1975 Honda CB550KComment
