Fuel Filter Air Lock
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    Hey guys, Can someone tell me how to get the air out of my fuel filter? Filters are new, flow direction is correct, fuel tank vent is not blocked, carb vents are not blocked and fuel flows freely from the petcocks but there is only a few drops of fuel In the filter at any given time.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • 8893
    There will always be a pocket of air in there, unless your filters are below the bowls. It should not affect operation.
    • 79XS11F
      • Jul 2006
      • 3563
      At this point there's a lot of air in them. they are not fully below the bowls but they are pretty close to it. Why is the air there? Should the filter not just fill up as a fuel line would?
      Rob
      1978 XS500E
      1981 Suzuki GS1100
        • 8893
        Rob
        You would think so, doesn't seem to work that way.
        I have air pockets in my fuel filters but they flow fine.
          • 9981
          Air floats........
          • 79XS11F
            • Jul 2006
            • 3563
            Originally posted by BA80
            Air floats........
            Yes it does and that's why I don't get it. That air should find its way into the fuel tank and leave the lines and filters full of fuel.
            Rob
            1978 XS500E
            1981 Suzuki GS1100
              • 9981
              Do you have the filters standing on end or laying on thier sides?
              • jjz28
                • Apr 2012
                • 1023
                • Beckley, W. Va.
                I have to find a way to route mine. I couldnt get enough fuel with them on there, I had air in the fuel lines and could not get them to fill up. I ran fuel lines straight to the carbs and that was a pain cause i had to cut them real short to keep them from crimping. I have clear lines. My tank is clean but i still want filters.
                77 XS750 2D completely stock
                • clcorbin
                  • Jan 2010
                  • 495
                  • Albuquerque, NM
                  Mine usually are at least 1/2 full of air, sometimes more. It bugged the crap out of me for a while. I EVENTUALLY quit worrying about it.
                  Of course, if you REALLY want to quit worrying about it, buy metal filters instead of plastic...
                  -- Clint
                  • mack
                    • 2411
                    • Ontario, Canada
                    Hi Rob
                    I had same issues, my motor was starved for fuel, could'nt even tune them properly. I just got rid of them altogether. You have filters in the tank, filters on the fuel valves, enough already.
                    mack
                    79 XS 1100 SF Special
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    https://youtu.be/wB5Jfbp6SUc
                    https://youtu.be/RaI3WYHSuWA
                    Frankford, Ont, Canada
                    613-398-6186
                    • BigRed
                      • Mar 2010
                      • 265
                      • Ottawa, Ontario, Canada
                      I had the same problem when my filters were lying horizontally on top of the carbs. Bike was starving before the fuel light would come on. I recently replaced my filters with smaller square ones, and installed them between the middle two carbs with fuel flow going up through them. I haven't looked to see if there's any air in them, but I was driving around nearly empty with no problems.
                      '80 SG with motor from a '82 XJ
                      • 79XS11F
                        • Jul 2006
                        • 3563
                        Well my issue that is not "fully" resolved with the misfire that's all over the map "may" be being caused by poor or inconsistent fuel delivery. With the engine running at idle the supply really looks like a drip, drip, drip. I may remove them or evacuate the air from the filters with a piece of small DIA heat shrink that will fit down the fuel line to the filter.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • ddragon63
                          • Jan 2012
                          • 1101
                          • Ridgefield, WA
                          I have mine on about a 30 degree tilt attached right @ the fuel T's on the carbs. There is just enough hose to connect the filters to the T's. And then the lines are crossed to opposite petcocks. With this set up I turn the petcocks to "Prime" and you can't count to 3 Mississippi before the filters are completely filled, and we're talking a foot of line on each and some up angles to make the cross-over from 1 side to the next. Fire bike and turn both pet cocks to on and the filters stay full.... even if I kick on the throttle lock @ 5,000 rpm and watch, they stay full...
                          Best check and make sure you don't have an air leaks in the line somewhere or a kink in the house. Or make sure there is no blockage in the petcock itself. I had a fuel flow problem once... turns out I didn't fully have the fuel in the full on position. hopefully you figure it out
                          Don
                          old:
                          1989 kawi ex500
                          1996 yzf-r6
                          1999 yzf-r1
                          2001 kawi zx-6r
                          2000 Ducati 748
                          2002 YZF-R1
                          2005 V-Star 1100 Classic
                          • petejw
                            • 2269
                            • sydney australia
                            if u have a crossover hose to join the
                            2 fuel lines together, what ive done in the
                            past is to have a fuel line conected to the tank,
                            and have the other fuel line disconnected and raised in a container,
                            turn on the petcock with the fuel line connected
                            and let the fuel flow thru until most of the air is out.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            1981 xs1100 RH (aus) (5N5)
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                            • jjz28
                              • Apr 2012
                              • 1023
                              • Beckley, W. Va.
                              Hey dragon, i guess this is on "old man"? Mine is a special too and i hate the way the petcock nipples angle in. I couldnt cross mine over without being kinked but i am going to try again, i bought 4' of hose.
