Hey guys. My bike is giving me the blinking warning light. I contacted the PO and he said that it was the kickstand sensor. Is there a way to disable it?
Blinking Warning light
Must be a XJ. Not sure maybe jumper the wires at the switch. Which warning light?Keep the shiny side up
1979 XS1100SF
Mac 4-1
Drilled airbox Uni filter
Vmax bars
Virago 1" shorter shocks
30K miles
http://i1228.photobucket.com/albums/...429_135845.jpg
1981XS1100SH
'80 G Forks and Triple Tree
'80 G tank
Mac Turnouts
Virago 1" shorter rear shocks
SH Headlight
http://i1228.photobucket.com/albums/...psd6adaae1.jpg
61 Wife
83 Son
86 Son
89 Daughter
Originally posted by Troney View PostThe big red one at the top of the cluster. Blinks constantly but I've taken it for a few rides and after a bit it goes solid then sometimes goes out.
the brake light would come on if it does not sence the correct load (not sure if it also comes on for low brake fluid level or if that is a different sensor). It you have a burnt out light or have LED's installed it will blink. The side stand is able to be bypassed i do not remember if you have to put a jumper on that plug or just disconnect it.Ty
78 XS1100E - Now in Minnesota
80 XS1100LG - The Punisher
82 XJ1100 - Daughter's Bike
Originally posted by TroneyIs there a way to by pass the stand sensor?
To bypass the sensor, which makes the circut think the stand is always in the UP position, you need to:
Remove the seat.
Follow the wire assembly up from the sensor to a connector just behind the fuel tank. Tank does not have to be removed.
Disconnect side stand switch wiring at the connection just behind the fuel tank.
On the bike side connector, all 3 wires have to be connected to each other. I made up a 3-way connector using 1/4 in spade terminals. Can't remember if they are male or female, seem to remember I used female connectors and speaker wire to connect the 3 wires together.
Replace seat.
Keep in mind this disables a safety feature. If you choose to do this mod and injure / kill yourself I am not to be held responsible.
Another approach is to fix the side stand switch. You can remove it, cut around the outside (not through) and remove the top end with its wires. Clean out the switch - it gets pretty dirty - and reassemble using a good epoxy to put the parts back to gether. Reinstall on the bike and give it a try. The switch has been discontinued from Yamaha, by the way.
Hope this helps.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
Originally posted by XJfan1Mine flashes because it does not have the right batttery in it. These have a water level sensor built into the battery.
http://www.xs11.com/xs11-info/tech-t...liminator.html
The write-up mentions a 2K ohm resistor; value is not critical and a 2.2k ohm works just as well.
Mod eliminates the flashing warning light and makes the system think the battery sensor is in place and within limits. This works on many Yamaha models of the early '80s and is not exclusive to the XJ.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
Originally posted by TroneyIt is showing Fuel, Brake, and Stand.
Again, to eliminate some warning signals, jumping the wires together from those sensors will generally do the trick. I would recommend fixing the underlying problem, though, and jump wires only as a last resort. The XJ's LCD system is generally pretty reliable and only reports problems comming in for the various sensors. Fix the problem, don't kill the messanger...Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
