Standard Yamaha hard bags on a 79 special?
  • Levi
    • Apr 2011
    • 8
    • Pittsburgh, PA
    Has anyone adapted (what I think are) Standard factory hard bags to mount on a Special? The chrome piece that goes from the top of the shock to the foot peg, at least I think that it is supposed to do that, doesn't fit.
    Basically, the angle of the piece that goes over the muffler is wrong. Any ideas?
    Thanks.
    Levi
    Levi
    1979 XS1100 Special
    Previously owned 1979 XS750 Special
  • ViperRon
    • Feb 2011
    • 1062
    • Woodstock, VA
    Your install points are correct but I think there is a difference between the Special and the standard and specifically I think the bar the foot pegs and muffler attach is actually a little different. I know on my 1980 G the original pipes and even the Mac replacements hang lower than what I see in the picture you have.
    Rodan
    1980 G Silverbird
    1198 Overbore kit
    Grizzly 660 ACCT
    Barnett Clutch Springs
    R1 Clutch Fiber Plates
    122.5 Main Jets
    ACCT Mod
    Mac 4-2 Flare Tips
    Antivibe Bar ends
    Rear trunk add-on
      The foot peg brackets (that the mufflers mount to) are almost straight back on the Standard models (ok, all but the Venturer / H models). On all the Special models they slope up as they go back. The stock exhaust follows that slope or lack of slope on all the models, the bend seems to be in the 4-2 collector piece.
      So the bracket that hangs the bags on a standard model does nto mount up to the Special models as you have discovered. The only way I could see it fitting would be to do some permanent modifications. I do not see how adaptor brackets would let the bags sit low enough and not interfere with the exhaust.
