If it worked corretly simply leave it in. It just makes it the same as all the XS11's and will perform better in the long run.
Please Help Guys
That's what most people do.
Sounds good I'll just leave well enough alone.
Also was wondering when it is running correctly which way should the choke be sitting? Looking down on the carbs should it be pulled all the way to left or all the way to the right?82 XJ1100
Very Little that is factory left.
Large mix of XJ/XS partsComment
All the way to the left is full choke. 1/2 way in is fast idle. Fully to the right is choke off/ run position.2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Couple of more parts bikes of which 2 more will live!Comment
Thanks I can't ever figure that out
. Till now the only way it would run was with full choke, now as it warms up I can ease all the way off and it will idle at around 1000 smooth and without a miss.
Thanks everyone with all the help.82 XJ1100
ok I have a really stupid question. How do you set the float heights in the carbs. I know how to measure them just not sure how to adjust them.82 XJ1100
You gently bend the little tab that sits on the float needle.Nathan
Theodore RooseveltComment
Took the bike out for it's first ride since rebuilding the carbs and readjusting everything on. All I can say is HOLY CRAP BATMAN!!!!!!!!!!!!!!!!
That monster scared the crap out of me. No miss what so ever, no popping, and no stumble any where in the rpm range. Just gut wrenching, rip the skin off your ass power!!!!!!
Thanks everyone for helping with fixing this thing and not letting me give up, Mitch82 XJ1100
Congrats on all the hard work!!! The more work it takes to get them running right, the better it feels when you succeed!Life is what happens while your planning everything else!
78 XS750Comment
Exciting the first time you feel the power and torque of one of these things running rightTook the bike out for it's first ride since rebuilding the carbs and readjusting everything on. All I can say is HOLY CRAP BATMAN!!!!!!!!!!!!!!!!
ain't it.
Scared the crap out of me when 1st - 3rd jerked the front wheel off the ground
. In 4th I was running 60 and only pulling 4000rpm with me and my ole lady on it.
Also a plus is with the pods on it it has a mean ass growl to it
82 XJ1100
82 XJ1100
Some folks have swapped out for an XS750/XS850 FD on these. If you look at the back of the FD (you can look through the spokes of the rear wheel) and see the model number on it. If it starts with a 2H7 that is the stock FD, if it has a 1JYO it is the XS750/850 FD.Life is what happens while your planning everything else!
78 XS750Comment
