Please Help Guys
    • 3193
    #61
    If it worked corretly simply leave it in. It just makes it the same as all the XS11's and will perform better in the long run.
      That's what most people do.
      • va_blue_stang
        • Aug 2011
        • 97
        • Bluford Il 62814
        #63
        Sounds good I'll just leave well enough alone.
        Also was wondering when it is running correctly which way should the choke be sitting? Looking down on the carbs should it be pulled all the way to left or all the way to the right?
        82 XJ1100
        Very Little that is factory left.
        Large mix of XJ/XS parts
          • 3193
          #64
          All the way to the left is full choke. 1/2 way in is fast idle. Fully to the right is choke off/ run position.
          • va_blue_stang
            • Aug 2011
            • 97
            • Bluford Il 62814
            #65
            Thanks I can't ever figure that out . Till now the only way it would run was with full choke, now as it warms up I can ease all the way off and it will idle at around 1000 smooth and without a miss.
            Thanks everyone with all the help.
            82 XJ1100
            • va_blue_stang
              • Aug 2011
              • 97
              • Bluford Il 62814
              #66
              ok I have a really stupid question. How do you set the float heights in the carbs. I know how to measure them just not sure how to adjust them.
              82 XJ1100
                #67
                You gently bend the little tab that sits on the float needle.
                  • 8893
                  Make sure you measure the float on both sides, additional bending may be required to get them the same.
                  • va_blue_stang
                    • Aug 2011
                    • 97
                    • Bluford Il 62814
                    #69
                    Took the bike out for it's first ride since rebuilding the carbs and readjusting everything on. All I can say is HOLY CRAP BATMAN!!!!!!!!!!!!!!!!
                    That monster scared the crap out of me. No miss what so ever, no popping, and no stumble any where in the rpm range. Just gut wrenching, rip the skin off your ass power!!!!!!
                    Thanks everyone for helping with fixing this thing and not letting me give up, Mitch
                    82 XJ1100
                      #70
                      Congrats on all the hard work!!! The more work it takes to get them running right, the better it feels when you succeed!
                        Exciting the first time you feel the power and torque of one of these things running right ain't it.
                        • va_blue_stang
                          • Aug 2011
                          • 97
                          • Bluford Il 62814
                          #72
                          Scared the crap out of me when 1st - 3rd jerked the front wheel off the ground. In 4th I was running 60 and only pulling 4000rpm with me and my ole lady on it.
                          Also a plus is with the pods on it it has a mean ass growl to it
                          82 XJ1100
                            In 4th I was running 60 and only pulling 4000rpm.
                            Sounds more like 5th with the stock final drive.
                            • va_blue_stang
                              • Aug 2011
                              • 97
                              • Bluford Il 62814
                              #74
                              It's always felt like it's geared fairly high. I never got to go in 5th yet. Only time I could ever get into 5th was running on the 4-lane.
                              How can I tell if it's the correct final drive for my bike?
                              82 XJ1100
                                #75
                                Some folks have swapped out for an XS750/XS850 FD on these. If you look at the back of the FD (you can look through the spokes of the rear wheel) and see the model number on it. If it starts with a 2H7 that is the stock FD, if it has a 1JYO it is the XS750/850 FD.
