Side Cover Safety
  • Aches n Pains
    • 349
    • Reston, Va.
    Side Cover Safety
    Has anyone figured out a way to bolt on (or other method) side covers. Tired of losing them on the road.
    Thinking of fishing line running through the bike and out a small hole in the side cover. Id you need to get to the tools or fuses you just cut the line.
    A second alternative would be a bolt into the mounting plate for the fuses on the right and a Riv-nut in the tool box lid on the left side.
    Thanks,
    Aches n Pains
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    Why not replace the rubber doo-hickies that hold them on? The bottom one on the right is available OEM and the top ones you may source from Mike's XS.
      Hmmm..........my thoughts exactly.......
        I've never lost one in ??????? miles on the highway. The right side has good rubber 'dohickys" and the left one has the hook broken off the latch but I just stuck a piece of duct tape over the end and shoved it in there and it stays good.
        • jayel
          • Apr 2012
          • 152
          • Birmingham, Iowa
          Drill holes and use nylon zip ties, easy than fish line or string ought to carry a few in your toolbox for spares and repairs any way
          where are we going, and why are we in this hand basket?
          Iowa the Beautiful Land 1980 XS1100SG
            I agree, replace tge rubber. I got a rubber electrical bulkhead groomed for 30 cents at ace for the lower one on the right side and it is nice and tight.
            • Cuda 69
              • Jan 2012
              • 676
              • Greenwich N.Y.
              my left one is broken on the bottom wear it locks,and I used heavy duty velcro,I haven't lost it yet.
              FOXS-XS11SG
              1980 XS11SG-sold
              1999 Vulcan classic-sold
              1982 XJ 650-sold
              • jjz28
                • Apr 2012
                • 1023
                • Beckley, W. Va.
                I am going to ride to lowes tommorrow and take my sidecover in and get some grommets that will fit on them. My lactch is broken too but i am getting ready to fab something for it that will look good and not tacky.
                77 XS750 2D completely stock
                • jayel
                  • Apr 2012
                  • 152
                  • Birmingham, Iowa
                  mine was also broke... dill a hole in the latch piece and another in the cover 90° to each other and close together as possible, zip tie them together in the correct (locked) posistion and use masking tape to build a dam for JBWeld (gluing latch to cover) leave zip-tie in place and cover it with the JB took about three separate sessions with the tape and fill, but latch to cover angle is thicker and stronger than before
                    On those two top pins all you need is some vacuum hose that fits tight to slip over them. As for the grommets, MIKES has some that may work where they pop in.
                    • Yahman
                      • Mar 2008
                      • 779
                      • Salem, OR
                      Originally posted by jjz28
                      I am going to ride to lowes tommorrow and take my side cover in and get some grommets that will fit on them. My lactch is broken too but i am getting ready to fab something for it that will look good and not tacky.
                      In a couple of weeks I will have a repair kit ready for the left side-covers. It consists of a black powder coated aluminum bracket that replaces the lock mechanism, and an aluminum pin that is attached to the side cover. All of the hardware is stainless steel. When installed, the side-cover will attach just like the right side.
                      I've been working on this for a few months now and it would be done if I could find more time.
                      Larry
                      82 XJ1100
                      80 XS1100G (Project bike)
                      64 Yamaha YA-6
                      77 Suzuki TS-185
                        You've got my attention.
                          There is no may about it. Part #02-6501 and #02-6504 in your link are the correct parts for the SF sidecover. They are also correct for the E and the F sidecovers. The second part is available OEM.
                          • Cuda 69
                            • Jan 2012
                            • 676
                            • Greenwich N.Y.
                            Larry,I'm intrested as long as it doesn't change the look of the cover on the outside.
                            FOXS-XS11SG
                            1980 XS11SG-sold
                            1982 XJ 650-sold
                            • Aches n Pains
                              • 349
                              • Reston, Va.
                              You guys have had better luck with the rubber "dohickeys" than I have. Just lost a side cover off my KZ Police bike and it's going to cost a bunch for a nice replacement. Looking for something with a positive lock rather than a friction lock.
                              Thanks for all the suggestions. May try the plastic ties.
                              Doug
                              1995 KZ100P
