Boot gave me the boot
  • KA1J
    • 664
    • Groton, CT
    Just drove to Boston & when I stopped to check for any loose components (replaced the exhaust) I discovered the large boot held at each end by springs (Looks like a CV joint boot) between the middle gear unit and drive shaft is torn at the small end. Yama part # 2H7-22189-00-00
    Since this boot is not spinning, is there a replacement available like on CJ joints where you can replace it and then seal the rubber? Or if not, what's the easiest way to replace it? I suppose I could use a piece of inner-tube and use adhesive to keep it on there. I don't want water or debris getting in there. I'll try and wrap it with tape for the moment.
    Idears?
    http://www.powersportsplus.com/parts...189-00-00.html
      Best way to replace that boot is to remove the swingarm. Good time to grease the swingarm bearings.
      • KA1J
        • 664
        • Groton, CT
        How much / long of a job for a first timer to remove the swingarm? If there's no available boot that can be applied while everything is in place, that's what i have to look at doing.
        Thanks for the replies!
          Shouldn't take you more than all day. I'd say about 4 hrs.
          • KA1J
            • 664
            • Groton, CT
            Ugh... Delightful...
              If you unbolt the driveline from the middle drive and remove the final drive the u-joint yoke will separate enough to carefully wiggle the new boot in there.
              • WSL91
                • Feb 2012
                • 427
                • Quad Cities, IL
                Sounds like a good time to pull the rear wheel and check/grease wheel and swing arm bearings. I've done it, not fun but glad to know its been checked.
                1970? Honda Z50... gone
                1974? Yamaha 100 Enduro... gone
                1974 Honda CB200... gone
                1981 Yamaha Virago 750... gone
                1993 Honda Shadow 1100... gone
                2008 Honda VTX 1800F
                1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                http://www.johnsoldiron.com
                • Jerry
                  XS & TRUE XJ GURU
                  • 3023
                  • Elma, IA.
                  Here is a tip that may help install the springs that hold the boot in place.
                  When I did my boot, I was having trouble getting the springs back in place. I put the springs roughly in place, then took a piece of light solid wire and ran it through the little eye and hook at the ends of the spring. I crossed the ends of the wire (made an X) and pulled gently. This drew the ends of the spring together and I was able to hook the 2 ends quite easily.
                  Might save some frustration and make the process go faster.
                  Jerry Fields
                  '82 XJ 'Sojourn'
                  '06 Concours
                  My Galleries Page.
                  My Blog Page.
                    Why not hook the 2 ends before you even start the installation? There is no reason to unhook them in the first place. I just replaced the boot on mine last week, and left the springs on the boot for the entire installation. I used a screwdriver to do the finishing allignment to get the boot to seat around the swingarm, but it wasn't all that difficult.
