Coil Question
  • Azoroth
    • May 2011
    • 82
    • Idaho Falls, ID
    Coil Question
    So today I went to ride around for some errands. Started to run like CRAP. Went up to my dad's house. I took out the coils and tested them. Outta spec and one was totally shorted out.
    So my question is... the two coils had different spark plug boots on them. The ones on 2 and 3 were just regular boots. #1 and 4 had 5 ohm resister caps. (One was measured at 50k ohm). Is this normal? Are they not supposed to be the same? What are they supposed to be?
    Obviously I need new coils. Any hints on where to get new ones? Is there another newer bike that might take coils that will work? If I could find coils that came from a 10-15-20 year newer bike, thats more use out of them for me.
    1980 Yamaha XS1100SG
    1984 Honda VF700F Interceptor
    1967 Yamaha YL2C
  • James England
    • 3039
    • North of England
    The HT caps should all be the same spec...often the middle two are longer.
    I'd use green Dyna coils.
    What model is it?
    • Azoroth
      • May 2011
      • 82
      • Idaho Falls, ID
      What model is it?
      My bike is a 1980 SG
      I wish that I could afford Dyna Coils. But I just spent all my money on a new house
      I looked online the cheapest ones I found were $120. Those were for the DC2-1 (Found that number from another thread).
      1967 Yamaha YL2C
        It's time to contact Andreas.
        • Azoroth
          • May 2011
          • 82
          • Idaho Falls, ID
          I just looked up the green Dyna coils. It says that those are 3 ohm coils. The stock ones are 1.5. How much will this matter?
          1967 Yamaha YL2C
            The XS used a 3 ohm system. The coils are 1.5 and the ballast resistor is also 1.5. If you use 3 ohm coils you just remove the ballast resistor, it is just another link in the chain to fail anyways.
