rear sets.
  • rear sets.
    hey, i was wondering if anyone out there made their own rear sets. i know stevestrom made some, but i don't think he is active on here anymore (last activity in november.) thanks in advance.
    1979 xs special, just finished the top end rebuild and then i still have lots of work.
    progress thus far...
    http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
    "If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
    Do you mean rear foot pegs?
      I supose you could put rearsets on an XS11, but when I think of rearset pegs, I think of sport bikes not 600 lb plus bikes. On my Special even the regular pegs fall pretty much back and I only have a 29" inseam and my legs feel lke they are more cramped than they are on my FZ1. The seating position on my bike just doesn't work well with foot controls that are under my butt.
      Can't beat the smell of gas & oil
        Exactly how far back are you planning to go with them, mate?
          There is a guy on the triples forum that has them and they look really good and he loves them. he has an xs750 wich is a lot like the 1100, i have one of each and they are a lot alike so they would probably be the same as his, he bought his though.
          77 XS750 2D completely stock
            Rearsets
            The British model of the XS1100 came stock with foot controls which are set back. They have linkage to the gear shift and a modified rear brake lever. The foot peg mounting plates are modified to accomodate these changes. This is a bolt on mod with no other work required. I acquired mine with the help of James England in England. The parts are much more available on UK Ebay because that's where that bike was sold. You don't see them over here that much. Contact James for more info. He is a member of this forum. I have had to make this mod due to the fact that the ergonomics of the US bike doesn't fit me. (6' 1", 30 inch inseam). They also have bars which fit this riding position. This is not a radical rearset, just enough to get my feet behind me. This mod also needs their shift shaft cover plate to accomodate the modified shifter linkage.
            Larry Walker
            Ham Radio kw4a
            ex Submarine Sailor (8 yrs)
            Dirt Rider 1970-1980
            Sreet Rider Touring 1980-2000
            Couch Potato 2000-Present
            1980 XS1100 Standard
            1979 XS650 Special
            2000 BMW R1150GS
              The 'euro' 2H9 version of the standard has different foot controls; they're moved back about 3" and up about 1" for more of a 'rearset' mount. The parts are bolt-on, but there's a bunch of them. You need the pegs, muffler/footpeg mounts, brake pedal, shift linkage, shifter cover, plus the hardware. Here's a pic of one of the pegs....
              You'll need to watch eBay in Britain and Germany to find these. One forum member here purchased a set, I believe it ran him about $150 by the time he got all the parts and shipping.
                I made some for my monoshocked bike but they may be a bit radical for you lads, the footrests are behind the swing arm pivot.
                Footrest, folding brake lever and master cylinder whilst being made
                The folding brake lever was made so it'd fold up out the way of the kicker as well as the footrest.
                More pics here
                Tom
                  was just wondering if this was about the standard? I am 6'4" and my special seems to fit me right.
                    The US versions all use the same forward pegs...
                      Raask makes them
                      http://raask.com/ind-eng.htm
                      Expensive though, I always wanted them.
                      Trapped in time. Surrounded by evil. Low on gas.
                      1980 XS1100G 1179 kit, Tkat brace, progressive springs & shocks, jardine spaghetti, Mikes coils, Geezer's rectifier
                        I was just looking for ways to increase the handling of my 79 special, and i wanted to go for a cafe look too. so thinking back to any tight turns i made at higher speed, the footpeg was the first thing to scrape, then the muffler or the center stand. so i was going to get rear sets and get a muffler that turned up so the bike could lean over more. i'm still on the fence about the center stand, not sure if i'm going to remove it yet. the convenience of it is great, but i want the bike stripped down.
                        • #13
                          yeah, i already found a bunch, but to save money, and for the hell of it, i want to make my own.
                          • #14
                            Make sure the suspension is up to the task before you get carried away... these bikes have never been known for their handling (how did that review go? Oh yeah...'these bikes can go fast, handle, and stop, but only one at a time...'), so make sure everything is up to snuff first...
                            • #15
                              thanks, i was looking at stiffening up the rear suspension, getting a tkat forkbrace, possibly getting xj shocks on the front or somehow upgrading the ones on there now.
