rough warm up
  • jjz28
    • Apr 2012
    • 1023
    • Beckley, W. Va.
    Thanks guys. Do you think that since the tabs are still on and the bike runs really well after warmup that maybe i should just leave those screws alone? I would have to pry the caps off to turn them and i like having the caps on there since they are original. I dont think i took the jet out of the bottom of the bowl for the enrichment and clean it, so i think that is probably what my problem is, do you guys agree?
    77 XS750 2D completely stock
      You are going to need to remove the caps, pull the screws and clean the passages underneath. The caps could be put back on if you are careful
      • jjz28
        • Apr 2012
        • 1023
        • Beckley, W. Va.
        The holes in the bowl were plugged, i unplugged them but havent put them back on yet. Thanks.
        • jjz28
          • Apr 2012
          • 1023
          • Beckley, W. Va.
          That did it! Now if i could just get it to run right!
          • tcoop
            • Nov 2009
            • 793
            • South Weber, UT
            I never knew that the 78/79 carbs had caps on the idle mixture screws. I've had four sets of carbs and not one had those caps. Learn something new everyday.
            Ty
            78 XS1100E - Now in Minnesota
            80 XS1100LG - The Punisher
            82 XJ1100 - Daughter's Bike
            • jjz28
              • Apr 2012
              • 1023
              • Beckley, W. Va.
              yeah, i am leaving mine on as long as i can. They have been on there for 12k miles now so hopefully another 12 thousand coming.
              • CaptonZap
                • Jun 2010
                • 1748
                • Denver
                If those are the same caps that are used on the 650's, they can be pried off and re-installed. Take a hair drier and blow hot air at them for a few minutes, to get them warm. There are a couple of tits on the underside that grip the needles. YMMV CZ
                • jjz28
                  • Apr 2012
                  • 1023
                  • Beckley, W. Va.
                  Thanks, thats good to know. I have a 77 xs750 and the caps are still on it too.
                  • jjz28
                    • Apr 2012
                    • 1023
                    • Beckley, W. Va.
                    I didnt want to start another thread. My bike runs really good now but pops on decel and i have read where i need to adjust my mixture screws. Wich way makes it richer? Is out richer and in leaner. thanks.
                    • petejw
                      • 2269
                      • sydney australia
                      yep thats correct,
                      screwing them out is richer.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      1981 xs1100 RH (aus) (5N5)
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
