82 1100 maxim headlight warning light, headlight works fine
  • #16
    on second thought
    I dont think I changed the headlamp warning lamp to LED IIRC
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • #17
      So Axel you changed all primary lights to LED?
      Are you still using the RLU with this setup without issue?
      • #18
        So far
        Just the instrument cluster lamps except signal indicators and headlamp warning . Red LEDs for the guages , diagnostic warning and green for neutral and blue for High Beam
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
