The final remaining electrical problem after restoring this 82XJ11' is that my headlight warning light is always on and the "head" LCD warning box is always on. The headlight itself works great, high and low beam with no issues. All other lights and electrical functions work, its just the headlight indicator :/
I've seen the headlamp indicator and high beam indicators on but at intermittent times when dealing with the headlight.
There is a headlamp, warning control and check button on the dash. Only the check button seems to be functioning. I Have no idea what the other two are even suppose to do. None are shown on any wiring diagram i've seen.
Ive opened the back end of the dash box, there is no corrosion or loose wiring that i can tell, but it is a big ole mess of wiring going to a covered computer board. Any insight would be adored!
