wired george ignition mod
  • Shockman54
    • Feb 2012
    • 145
    • Minneapolis, MINN.
    was just wondering if anyone has done this mod, and if its really as effective as he says it is. also if they have any pics of the process or finished product.
    thanks in advance!
    1979 xs special, just finished the top end rebuild and then i still have lots of work.
    progress thus far...
    http://s1268.photobucket.com/albums/...t=IMAG0202.jpg
    "If it runs bad, it's usually the carbs. If the tires go flat, I suspect the carbs. If the wind blows the bike over, the carbs were probably to blame. If my wife yells at me about something, I tell her to talk to the carbs" -Incubus
    If your wiring is in good condition and all the connections are clean, you won't see much if any diffference....
      • 8861
      thanks in advance!
      http://www.wgcarbs.com//index2.php?o...ge=0&Itemid=26
      Yes, I run that mod on both my bikes. Voodoo electrics at it's best, . Make sure you have 3 ohm coils, not the 1.5's.
      • Shockman54
        • Feb 2012
        • 145
        reason i ask is the bike has trouble starting, and i feel like the problem may be electrical more than gas/air mix. would putting the coils from my 81 parts bike make a difference? i already went through and cleaned all important electrical connections (haven't made it to the lights yet, im going to replace those anyway)
          • 8861
          If you are going to use the 81 coils (3 ohm), remove/bypass the ballast resistor. The 3 ohm coils provide a hotter spark, JMHO. If your battery is old and on the weak side, that could be part of your problem.
          • Shockman54
            • Feb 2012
            • 145
            ok, will do. and the battery is old, but puts out good voltage. i think i am going to get the Odyssey battery eventually, i have been hearing great things about them.
            • petejw
              • 2269
              • sydney australia
              ive done the same mod,
              stick a volt meter on the red/white wires
              from the coils, u should get 12 volts,
              if u do theres no need for the mod,
              i did it cause i was getting 11 volts,
              and was to lazy to go thru all the connections.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
