R6 left control mod
  • lee_dutcher
    • Apr 2009
    • 822
    • mason city iowa
    R6 left control mod
    ok so after 2 weeks i finally got my left control from a 2004 R6. i wanted to change the left control because like many other members the headlight control knob keeps breaking and the solder on the turn signal switch keeps coming detached. i wanted somthing more modern and durable.
    here a picture of the r6 and the xs1100 controls...
    heres the wiring...
    ok so this is the wiring xs1100 wiring on the left r6 on the right
    XS1100-R6
    Pink-Light brown/dashs
    Dark green-Dark green/dashs
    Dark brown-Dark brown/dashs
    Light brown/white stripe- Light brown/white stripe
    Yellow/red stripe, blue/yellow stripe, light green-Red/yellow stripe
    Yellow, blue/green stripe- Yellow/dashs
    Black- Black/white stripe
    Pic after button up and wraped in High grade electrical tape
    here is a video of everything working minus the horn (DOES WORK WITH THIS WIRING) just didnt have room for the horn due to the dyna coils are in the way...
    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
    1980 gs1000g "stock"
    2008 jmstar 150cc Chinese scooter ( wife's bike)
  • 81xsproject
    • 3185
    • Fortuna, CA
    I have a very similar one on mine. OEM controls are very easy to swap and the feel is so much nicer. The best part is the large supply out there.
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • lee_dutcher
      • Apr 2009
      • 822
      • mason city iowa
      Well i would of liked the oem but for a nice looking one would of cost me 36 ish plus shippibh. Got this one for 23 shipped saved a little money...
      • le_bucheron
        • Sep 2012
        • 45
        • Montreal, Quebec, Canada
        I try to do to same mod on my xj1100 83 and i have not the same wires colors...
        On my xj:
        Pink
        Dark green
        Dark brown
        Light brown / white stripe
        Yellow / red stripe
        Yellow
        Black
        Blue / black stripe???
        I don't have on my xj:
        Blue / yellow stripe
        Blue / green stripe
        On my r6 05 controls I have:
        Light brown / dashs
        Dark green / dashs
        Dark brown / dashs
        Red / yellow stripe
        Yellow / dashs
        Black / yellow stripe = clutch switch
        Black / dashs???
        Blue / yellow stripe = clutch switch
        What you thing?
        83 XJ1100
        06 FZ1 naked abarth
          This isn't a straight swap; you have to identify the wires and what they connect to.
          On your XJ, the wires are:
          Pink, goes to the horn button. You'll have continuity to ground (black) when pushed.
          Black/blue; power to the high/low headlight switch.
          Yellow; high beam, to the gauges. When the switch is on 'high', you will have continuity between this and the black/blue.
          Green; low beam, same check as yellow except on 'low' (you didn't list this wire, but it should be there).
          Black, ground wire for both the turns and horn.
          The rest are turn signal wires.
          Brown/white is incoming power. If you're removing the XJ hazard switch, this needs to connect to the brown/white coming from the flasher to the hazard switch.
          Yellow/red; this connects to the flasher canceller, and will have continuity to ground (black) when the switch had been pushed either way (left/right). If you manually cancel at the switch, this should read open to ground.
          Chocolate (dark brown) goes the the left signals. You will have continuity between this and the brown/white when the switch is pushed left.
          Dark green goes to the right signals. Same as left.
          Because the colors don't match, you'll either have to get a wiring diagram for the specific bike the controls are off of to identify them, or manually trace the wires to see what the function is (I'd recommend the latter to be sure).
