axle shaft swap
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    axle shaft swap
    While beating my axle shaft out with my 3lb sledge, I might have messed up my threads.
    Are the axle shafts the same on the SG and G?
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    All the axles are the same....
      What did you find to be the problem George?
      • DAVINCI
        • Jan 2011
        • 1048
        • Cedar Mountain, NC
        Occasionally we've all had to hammer a stuck shaft BUT you should install the nut before you do. The castellated nut should be threaded on backwards. This will help save your threads.
        • GLoweVA
          • Jun 2011
          • 1957
          Thanks Steve.
          I did have the nut on while beating it, but I had to eventually take it off to continue to get it all the way!
          Okay insert se#ual comments here.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
          • DAVINCI
            • Jan 2011
            • 1048
            OMG What the heck was rusted?
            • GLoweVA
              • Jun 2011
              • 1957
              The shaft itself was slightly rusty and had a lot of dried greasy grime stuff.
              A little pb blaster and some acetone and it cleaned up real nice.
              unfortunately I think my threads got too beaten up but I just got done pulling the shaft off my SG so I'll use that one until I can figure out what to do about the messed up one.
              The Green Monster
              Got him in '04.
              Scarlet
              Got her in '11
              Hugo
              Cold weather ride
                I have a Harbor Freight "thread cleaner" kit. It does NOT have much metric, but it DOES HAVE a metric thread FILE! I've used it to clean a few larger bolt threads, and with a little work, they are like new. You should be able to find just the file at most good auto parts stores, as well.
                • mjpxs11sh
                  • Jan 2011
                  • 299
                  • N/E, Illinois
                  Davinci
                  arent you putting the nylon threads at risk by turning the castle nut around or will they rethread when reinstalling it
                  Max
                  81 XS1100SH Black Beast Mutt
                  Kerker 4/1
                  stock carbs and air box.
                  78 headlite, handle bars,
                  1 set of ea-160/85mph guages,
                  crash bars, cruise control
                  Other 2 Wheelers
                  78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                  94 CBR1000F jet kit,Two Bros pipe, K&N Filter
                    Had that same issue with Banshee when I first got it. Both axles were corroded in place from sitting still for years in the elements. I always use a block of wood between the bolt and the hammer until it gets even with the mating surface, then I use my 3/8" ratchet extension as a "pushrod" and rubber mallot. If the rubber mallot won't do it, back to the BFH. But the small end of the extension is smaller than the threaded area on the axle.
                    As to your axle, If it were me, I would use a file of some sort like Ray suggested and clean the threads up as much as possible, then buy a large nut of the same threading at the hardware store and use that to finish "rethreading" it. Typically they clean up pretty well using that method.
                    • DAVINCI
                      • Jan 2011
                      • 1048
                      mjpxs11sh
                      I think you may be confusing nylock and castle nuts. Castle nuts are secured with a cotter pin. Nylock nuts have a nylon insert.
                      • WSL91
                        • Feb 2012
                        • 427
                        • Quad Cities, IL
                        I place a large screwdriver through the holes on the other end of the shaft and rotate and pull. Saves beating on threads.
                        1970? Honda Z50... gone
                        1974? Yamaha 100 Enduro... gone
                        1974 Honda CB200... gone
                        1981 Yamaha Virago 750... gone
                        1993 Honda Shadow 1100... gone
                        2008 Honda VTX 1800F
                        1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                        1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                        http://www.johnsoldiron.com
                        • tom clisham
                          • Sep 2010
                          • 627
                          • Northern Illinois
                          I can send you one
                          I've got a box of axles. PM me with your adress. i can priority mail it to you. Just pay for mail. I believe around $5.00 if it fits the bos I've got in mind.
                          BTW: front or rear?
                          Tom Clisham
                          Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                          _____________________________________________
                          '78xs1100E ,all stock & original GONE TO WISCONSIN
                          '80 SG Vetter fairing,hard bags,trunk,fork brace,
                          stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                          79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                          79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
