Brake Pads Wearing at an angle
  • JoshKeast
    • Mar 2012
    • 53
    • Treynor, Iowa
    Hey everyone. So I'm almost ready to fire up the bike, just waiting on new plugs and new pod filters from MikesXS. I went through the brakes while waiting, and I needed to because there was almost no fluid in the lines to speak of. Anyway, the pads are worn at an angle, there is alot of play at the hinge pin that is allowing the pads to be torqued at an angle. It looks like it is supposed to be that way though as all four pads have the exact same hole size.
    I was just wondering if this is common or if I need to replace something?
    1981 XS1100 Special
    "A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed." 2nd Amendment
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    the brakes should be angled and there should be some play at the hinge pin.
    the caliper should just kinda hang there.
    testing 1-2-3
    1980 1100 mns
    • tom clisham
      • Sep 2010
      • 627
      • Northern Illinois
      Angle is correct form
      They're made that way. Brand new ones will have same angle cut. Kinda wierd first time you see it.
      Tom Clisham
      Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
      _____________________________________________
      '78xs1100E ,all stock & original GONE TO WISCONSIN
      '80 SG Vetter fairing,hard bags,trunk,fork brace,
      stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
      79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
      79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
        Originally posted by JoshKeast
        - - - Anyway, the pads are worn at an angle, there is a lot of play at the hinge pin that is allowing the pads to be torqued at an angle. It looks like it is supposed to be that way though as all four pads have the exact same hole size. - - -
        Hi Josh,
        lucky you, to ask before tossing the pads and then finding they were supposed to be tapered when the new ones showed up.
        Weird innit?
        Almost as weird as the engine turning backwards.
        Took me months to find that out, too.
