xs11 carb diaphram spring
  • wmjoyner
    • Sep 2002
    • 4
    • Drummonds, Tn
    hey all. i was doing spring cleaning on the 78 xs11e carbs and found that one of the diaphram springs is bent. i found one on ebay for a 78 xs750e and was wondering if anyone knows that this would work. that is since the 750 is basically the 1100 with one less cyl.
    would greatly appreciate any input as i'm ready to get this thing back on the road and enjoy some nice cool weather riding!
    mike
    Nope, not the right spring. That is a '78-79 XS11 part only...
    • TADracer
      • 1417
      • Kenner, Louisiana USA
      How bad is it bent? Had one that was a bit crooked (the coils were not kinked) but it just was not straight. Was a bit longer than the rest also. I accidentally stepped on it when I dropped it on the floor. I carefully straightened it out with some needle nose pliers and made sure it was the same height as the rest. Ran it for years and though I do not run those carbs anymore, that spring is still in my retired set of carbs.
      Mike Giroir
      79 XS-1100 Special
      • mack
        • 2411
        • Ontario, Canada
        Are you sure
        Steve, the triple carbs I'm working on now have diaphragms and springs identical to the 78 even carbs I was salvaging the fuel T's for.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
          Spring rate also matters though. Length and diameter can be the same but strength can.be different.
            The parts fiche show the diaphrams/slides as the same, but not the springs; as Nate said, it's probably a different rate....
              • 5048
              A slight bend in the spring should be no problem. The caps have a circular flange to center the spring...
              • wmjoyner
                • Sep 2002
                • 4
                • Drummonds, Tn
                thanks for all the great replies!
                i was afraid it would be different. springs this size can have such subtle differences. spring rate is something i was concerned about. and with the age of the springs, if i can find em new, replace em all at once.
                straightening out is my last resort. the bent coil is stretched out and kicked to one side. i'm concerned there will be a weak point in the spring after this if i start bending.
                i'll not throw it out tho! all this stuff is to valuable! i'll use if no other option.
                if anyone runs across a good sample please let me know.
                i'll keep lookin and watchin ebay. a much wiser shopper for sure!
                mike
                • mack
                  • 2411
                  • Ontario, Canada
                  E Springs
                  Let me look through my stuff. I may have a spare or several.
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • mack
                    • 2411
                    • Ontario, Canada
                    Yep
                    just checked and I do have a spare, PM me with your particulars and I'll send it down. Need anything else, I have a few spare parts for E carbs. STEVE, no surprise, while I was in the shop I checked the springs and your right there is a noticable difference in the stiffness.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
