need help badly
  • Matt78
    • Apr 2012
    • 17
    • Punxsutawney, Penn.
    need help badly
    ok when i first got my 79 xs11 i would idle w/choke out but when i gave it gas or put the choke in it would stop running...fixed that tore carbs apart cleaned well now it wont idle but i can put choke in and give it gas to keep it running replace jets outside carbs have 175's inside have 155's i was told it was ok to do this by local yamaha parts dealer as long as carb 1 & 4 had same size jet and 2 & 3 hand same size jet any thoughts and where can i but petcocks for this thing . thanks matt78
  • GTXS1100
    • Jun 2010
    • 224
    • Columbia MO
    What mods do you have on your bike? Is it stock? Im not for sure but i think your jets are way too big. Im pretty sure that 137.5 is stock for a 79. Im sure someone on here will be able to tell you for sure. Welcome to the site.
    80 XS1100G Black Betty (Daily Driver)
    79 XS1100SF (Buddys Project)
    82 XJ750 Maxim (Fathers Bike)
    81 CB750F SS (Buddys Project)
    06 GSX600F Sold! (Was Mine)
    81 XS1100 Failed Bobber Project (Mine)
    81 XS1100 Parts (Mine)
    Grip it, Rip it, and Stick it!!!
      Hey Matt, welcome to XS11.
      As indicated, the stock jetting on a 79 was 42.5 pilots with 137.5 mains. The jetting your using is huge!! Look at your plugs and see how wet/black they are. I would think they look like a coal miners convention with those jets.
      Yamaha did offset the jets on the outer carbs from inners to cool the inside cylinders as emissions required leaner running conditions. But they went away from it as it really did not do anything for them.
        Guys, he's talking about the main air jets on the outside of the bell on the intake of the carbs. I was thinking they were like a 180 or 185? But I've been wrong lots before.
        Matt, if someone told me that it was OK to run jets 4 sizes different than the others on the same motor.... That would be one less person I'd listen to for advice. Just my 2 cents.
        My first check would be to remove the idle mixture screws to see if you have tips broken off of them. They should be nice and pointy. Keep track of where they are to begin with though. Screw them down, counting the turns, until they VERY LIGHTLY SEAT. A light pressure with the thumb and forefinger, then install them to the same spot after you remove and check.
        • Matt78
          • Apr 2012
          • 17
          thank you all for the help ....btw the bike was free and its my first bike lol
            Well, congrats on one heck of a deal if it runs at all. Now, look under the FAQ section of the site and find the "What to look for in a Neglected XS11" thread and read through that.
            Also get a manual and go through ALL of the maintenance recommendations.
            As to the jetting, are you speaking of the air jets or the main jets as being those sizes? Main jets are in the bowl area of the carb, the idle air jets are in the inlet bell.
            • GTXS1100
              • Jun 2010
              • 224
              • Columbia MO
              Be Careful these machines are beast and can get away from you. Just respect her and you will be fine. Congrats on the great deal. Hope you get the bugs worded out of her.
                Since you stated it is your first bike, I also STRONGLY suggest taking the MSF basic rider course. Even the old salty dogs say they learn something in that class.
                • Aches n Pains
                  • 349
                  • Reston, Va.
                  We want pictures!!! A free XS11 is everyone's bike porn.
                  Have you torn the carbs down completely and cleaned everything. Often takes two or three times to get them right. Good pracice.
                  As with the others, this is a big bike. It's heavy and it is a handful. BE CAREFUL and take a class or two. Spend a bunch of time in an empty parking lot figuring out clutch, throttle, and brake.
                  You'll love her but you've got to respect her.
                  Aches n Pains
                  1995 KZ100P
                  Pods, jets, pipes, cam adjuster, oil cooler
                  1977 Ironhead - custom build
                  Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                  Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                  • GTXS1100
                    • Jun 2010
                    • 224
                    • Columbia MO
                    Hahaha! Bike porn. Ill have to remember that one.
                    Yes post picks plz. Why doesnt this site have a photo gallery?
                    I think it would be cool to look threw what other people have done with there bikes. There are so many possibilitys and different bikes out there.
