My baby so far this year
  • GTXS1100
    • Jun 2010
    • 224
    • Columbia MO
    80 XS1100G Black Betty (Daily Driver)
    79 XS1100SF (Buddys Project)
    82 XJ750 Maxim (Fathers Bike)
    81 CB750F SS (Buddys Project)
    06 GSX600F Sold! (Was Mine)
    81 XS1100 Failed Bobber Project (Mine)
    81 XS1100 Parts (Mine)
    Grip it, Rip it, and Stick it!!!
  • GTXS1100
    • Jun 2010
    • 224
    • Columbia MO
    No Thoughts, oppinions, comments?
    • jjz28
      • Apr 2012
      • 1023
      • Beckley, W. Va.
      Nice man, looks good. Do you have the exhaut rap on your pipes (headers)? I was thinking about wrapping my pipes.
      77 XS750 2D completely stock
        I like the round headlight. I would change the clocks to round ones or get a big headlight from a Seca for the square ones to hide behind.
        I like your choice of colors.
        • GTXS1100
          • Jun 2010
          • 224
          • Columbia MO
          Yeah i cant keep that headlight on there. It doesnt work worth a crap at night but it looks good. I wanted to get the special light and gauges but all the ones i have found people want an arm and a leg for them. thanks tho
          • GTXS1100
            • Jun 2010
            • 224
            • Columbia MO
            I would like to use header rap on the whole thing but it can get pretty expencive. I just have it half way back i think it looks pretty good. Sounds Good too. I have some more pics ill be posting soon.
            • GTXS1100
              • Jun 2010
              • 224
              • Columbia MO
              There is alot of orange pearl in the clear you can really see it in the sun.
              Its platnum gray with rasberry stripes. i think it turned out pretty good for some paint that i just had layin around the shop.
                Nice metal flake paint and I like the striping. Thought about ghost flaming my tank and flowing it into the side covers, but I think that is been overdone lately anyway.
                The round headlight does look nice, I was wondering how you held it in place as I see no brackets on the fork tubes.
                  Hi GT,
                  MikesXS sells a complete new 7" headlight for ~$70 or mebbe 1/2 of that for a used one at your average swapmeet.
                  Round speedos from any XS series bike will fit and read correctly.
                  The round electronic tach is only found on XS11 Specials.
                  It reads correctly too but it don't have the Standard's fuel gauge in it.
                  There's a red "low fuel" warning light instead and to make it work you need the thermistor sender out of a Special's gas tank.
                  Which will fit in your Standard tank but needs to be installed with it's wires pointing forward or it'll be in there upside down and won't turn the warning light on until there's only ~ a 1/4-mile of reserve gas left.
                    Not only does it get expensive, it also likes to rot pipes
                    • GTXS1100
                      • Jun 2010
                      • 224
                      • Columbia MO
                      I made a bracket that bolts to the bottom bolts of the bottom triple tree mount. I was pretty easy i just used a piece of angle iron from the hardware store downtown. The light has a mounting bolt on the bottom of it and i drilled a hole in my angle iron for the mount.
                      • GTXS1100
                        • Jun 2010
                        • 224
                        • Columbia MO
                        Ill just keep the square tack and speedo till i can find a set off of a special.
                        They work good enough for me they just dont look right.
                        • Nightengale
                          • Jun 2011
                          • 521
                          • Hampton, VA.
                          headlight
                          i have a small headlight like yours on mine, mine is a sidemount and i had to reverse the headlight ears, and it bolted right up. it is really tight and i am getting ready to switch my bulb out for one that you can get from your local auto parts store, it has the same connection as the original headlight so it will just plug right in. alot brighter than the one that came with the light.
                          xs1100 hartail bobber
                          http://i1169.photobucket.com/albums/...-38-36_563.jpg
                          • Nightengale
                            • Jun 2011
                            • 521
                            • Hampton, VA.
                            special speedo and tach
                            i have a special speedo and tach, and mounting brackett that was given to me but wouldnt fit right with my project, and you can have them it you like. send me a pm if your interested.
                            • Nightengale
                              • Jun 2011
                              • 521
                              • Hampton, VA.
                              forgot to mention
                              and yes it is off of a special (round gauges). the speedo is fine but the tach is toast. but at least that way all you have to do is get a tach.
