Originally posted by pgg
Blaster, the K&N filter is a fine metal mesh type. To clean it you swish it around in a dish of turps or suchlike. The advantage is you can use it indefinitely. It gives more airflow but you need a 4-1 or unrestricted 4-2 and slightly larger jets to get the full advantage from it. The result is probably only a couple more H.P. but the motor feels more responsive. A well designed 4-1 definitely gives the motor more top end kick.
