went to change my oil and stripped the hell out of my oil filter bolt. never even got it loose so i think im just not gonna change the filter this oil change....
oil filter bolt
oil filter bolt
79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
09 YZF-R1 " Toothless"
04 Buell XB12R "Butterfly"
"I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
Wolf
Moto Militia MCTags: None -
Will it not come off with vice grips? If you can get a hold, maybe you could take a grinder and grind of the side a little to get a good bite. Just a thought, i have had to do that before and i belive partsnmore sells the bolt.Jeff
77 XS750 2D completely stock
79 SF XS1100 "Picky" stock with harley mufflers -
i could get it with vice grips, but i dont want to take it off until i get a new one and since its my only transportation at the moment, i will wait on it. the filter has only gone through one oil cycle so it wont kill it to just chill in the housing until i get a new bolt this week.79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
Moto Militia MCComment
i could get it with vice grips, but i dont want to take it off until i get a new one and since its my only transportation at the moment, i will wait on it. the filter has only gone through one oil cycle so it wont kill it to just chill in the housing until i get a new bolt this week.Joab
"If nothing else, it will be interesting..."
______________________________________________
1979 XS1100SF
1972 XS2 650
Ozark, AlabamaComment
Pretty hard to get a good square grip with the vice grips as the bolt head is not flush with the rest of the casting and you can't get on it square. I have the same problem and I've decided to sacrifice mine and have a new bolt here now for the next oil change. Next time its whatever it takes1970? Honda Z50... gone
1974 Honda CB200... gone
2008 Honda VTX 1800F
http://www.johnsoldiron.comComment
I still haven't managed to get mine off...I am just hoping and praying there is a really, really good filter in there...Joab
1979 XS1100SF
1972 XS2 650
WSL91, im going to do the same...i screwed it up a bit last oil change and remember thinking i should order another one but forgot.
joab, i usually just change my filter every oil change on all my vehicles, ive had trucks race cars and now bikes, just a little 'peace of mind', as filters arent expensive. however i did put some marvel mystery oil and motul motorcycle engine restorer before changing the oil, and ran it a few times ( ran, not ride, big difference ) before changing the oil, and with the change got most of it out but if not mistaken, the filter housing holds about a half quart so im sure some of that stuff is still in there...79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
Wolf
joab, i usually just change my filter every oil change on all my vehicles, ive had trucks race cars and now bikes, just a little 'peace of mind', as filters arent expensive. however i did put some marvel mystery oil and motul motorcycle engine restorer before changing the oil, and ran it a few times ( ran, not ride, big difference ) before changing the oil, and with the change got most of it out but if not mistaken, the filter housing holds about a half quart so im sure some of that stuff is still in there...Joab
1979 XS1100SF
1972 XS2 650
oil filter bolt
This has happened to many guys, and there have been as many posts as to the solution. I ground down the edges of the bolt with a Dremel to the next smallest(11mm) size, and managed to get it off. There was a smart post about taking the old, mangled bolt and welding a larger head on the end; more leverage. I've still got that bolt, but never got around to the mod. I just learned to go easy on the install.Comment
On my xj650 I ended up using a 1" step drill to take the head off after getting a new bolt. The new bolt I got from the stealership had a much deeper head, the hex was about 1/2" deepBARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
80 XS1100SG(cafe in progress *slowly)Comment
