I found the caps for the front and rear trans. It requires an allen wrench. I have all kinds of Allen wrenches but not one that size. Can anyone help with the size?
Transmission question
8mm
Hi Virstens,
Make sure you have the filler hole opened before you open the drain hole and loose all the oil
with no hole to refill
Be sure to use METRIC Allen wrench as you need the proper fit to not strip it.
Soak with PBBlaster or even WD40 to help loosen the threads. They can be real bastards to get out especially if the bike has sat for a long time.
If choosing synthetic apparently you need 80/140 for Dino oil 80/90 as the manual says.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
Hi virstens,
Dino refers to the dinosaurs. some people suggest their bones are what mineral oil is made from. The crude stuff
Yes 20/50 is getting more difficult to find.
Yep, metric allen "Hex head" wrenches for our metric bike!
The hard tool to find is the metric channel locks!
JJ.
Dino is natural crude, recommended for the engine proper, but it's perfectly okay to use SYNTHETIC for the middle and final drives gear lube oil.
Also, make sure the 20/50 you found does NOT have any friction modifiers, the upper half of the SAE circle should be blank.
T.C.T. C. Gresham
Yup, your right Phil.
Sorry my bad. That's what I get for trying to work from memory.
that's just too funny....I remember my first day in machine shop...they sent me to get a metric channel locks from one guy...that wasn't funny then..it is now thou
Nick
1982 Virago 750 (it's alive!)
1979 XS 11 F, Windjammer IV, Samsonite luggage cases(another rescue)Comment
I started into Carpentry at 15, Got sent for the left handed hammer and screw driver set.
Fortunately for me, my father was a carpenter (how I got into the work) and he was left handed, so I knew better. But I played along, went somewhere else on the job site and did some other work for a couple hours, came back with this puzzled look. They all laughed for a while. Easier to let them think they got me on an easy one than make them try harder.
78 XS750Comment
Hey Virstens,
Sorry, my bad, the Castrol GTX you found is good stuff, the energy conserving phrase is in the LOWER half of the API seal! That darn CRS gets me sometimes!
T.C.T. C. Gresham
The one on the left is correct......
The one on the right is not.Greg
Working on the flightline in the Air Force, the new guy always gets sent to get the keys for a certain jet... usually the general's to add more urgency. (For those puzzled, they don't use a key) That and a bottle of pneumatic fluid.Try your hardest to be the kind of person your dog thinks you are.
The allen socket in the head of the filler plugs are notorious for rounding off making removal a bitch. When you put the filler plugs back in here is a little tip that will make them much easier to get off next time. At an auto parts store buy some of the large size copper washers for banjo bolts used on brake systems. They are the right size and will seal the cap off with just a snug.Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
