Rebuilding carbs thinking of going with new viton tipped float valves to possibly help seal verses the original? Have you ever tried them?
Viton Float Valves
Tags: None
For which bike? Your 79 can't use them unless you've got later carbs, and your XJ already uses them. The float needles/seats are totally different between the two sets. The later seats push in with an O-ring seal and the early models screw in.Try your hardest to be the kind of person your dog thinks you are.
*Crashed/Totalled, still own -
There are needle and seat sets that will fit the XS carbs but they are actually for a Virago I believe.
But then, you are on your own figuring out the float level setting.
I meant to tell you the other day Gordon, get it running good with STOCK stuff first and then decide if you want to change things up.
Your going to have a tough enough time that way. Why make it harder?Greg
The list changes.Comment
I was looking at them them on ebay for 78/79 xs1100? Georges offers them on ebay for this year? I have bought some brake rebuild kits from him and seems like a good company?
82 XJ1100J
81 Venturer
Newly acquired Aches N Pains collectionComment
Greg sounds like a plan I will do just that one question when I pulled the bowels the float valves had no retention clips is this normal for this year ? Or should I look to put some on82 XJ1100J
81 Venturer
Some have complained that the clips cause the floats to stick but I have them on mine, along with the stock brass needles, with no issues.
Either way is OK just make sure the float drop is adjusted so the needles can't bind up.Greg
Thanks I will leave them just the way they are
Lots to learn!!82 XJ1100J
81 Venturer
Absolutely the best advice I've seen BA80!................Life dealing with these scoots would be much simpler if more would adhere to these principles!81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
